Urgeoner
Urgeoner's Avatar
12.11.2009, 10:52 PM
So as it looks atm, 6 mm shaft? And how do you guys think it will fit Muggy w/RCM motor mount?
Semi Pro
Semi Pro's Avatar
12.12.2009, 01:53 AM
it wont without modification,the rcm muggy mount is ment for 3mm screws and this motor uses 4mm screws
Urgeoner
Urgeoner's Avatar
12.12.2009, 01:27 PM
ok, so just make the hole slots in the mount 1mm larger then?
bruce750i
bruce750i's Avatar
12.12.2009, 04:17 AM
Para:yeah that was lame but really that's all I ended up doing but it took me about two hours. I just didn't want to fubar it up. The flat spot was stripping The sand off the sand paper strips, my files just smoothed over and buffed the shaft, So I whipped out the Dr with the cutoff wheel for most of it.
12.12.2009, 12:58 PM
I think a flat piece of grinding stone would have been the ticket, and some way to hold it parallel to the motor shaft. Maybe have a pivot so that you could "feed" it towards the motor shaft as the shaft is spinning.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
12.12.2009, 01:31 PM
A custom front motor cover would be a better idea - it would be easy enough to make the front cover attach via the m4 motor holes and leave a pair of m3 tapped holes to attach to the motor mount.
sikeston34m
sikeston34m's Avatar
12.12.2009, 01:42 PM
Have you thought about offering the RCM Pinion Gears with a 6mm bore?
Looks like the demand for these will be on the increase.
Unsullied_Spy
Unsullied_Spy's Avatar
12.12.2009, 06:13 PM
Any chance of getting you to make some of these? What options would we have as far as pinions? Because I like to run huge tires I need a smaller one than others are going to need so I may be SOL but it would be nice to have some for the other people that don't need smaller pinions (I'll need 10-12T). I may also mod my CD mount to accept a 51T spur, which would open up a lot of gearing options.
Urgeoner
Urgeoner's Avatar
12.12.2009, 11:12 PM
Ya ditto...also I would buy a couple 6mm pinions
Duster_360
12.14.2009, 10:02 AM
Put me down for several.....
Maybe Castle could send folks looking for 6mm pinions your way...
RC-Monster Mike
Site Owner
12.12.2009, 01:48 PM
I hadn't thought about 6mm bore pinions, actually - even with this motor I think the demand will be quite small in the grand scheme of things. If I did do hardened 6mm pinions, I wouldn't offer the whole range for sure.
bruce750i
bruce750i's Avatar
12.14.2009, 10:42 AM
Here is a picture of how my shaft re-size turned out. A good digital caliper is a must. I also kept an old rotor magnet close to the grinding to snatch any metal bits in addition to punching the shaft out of a zip lock bag. http://i300.photobucket.com/albums/n...d/DSC07227.jpg
12.14.2009, 01:01 PM
Nice job on that
snellemin
2 KiloWatt RACER
snellemin's Avatar
12.14.2009, 01:04 PM
Looks good man. Picture kinda says: "Hey, look at my "shaft"!"
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Unsullied_Spy
12.14.2009, 09:37 PM
It's here! I think I'll just grind my shaft down, I've been waiting for nearly a year for these to come out so I'm a bit uneasy grinding it down but here goes nothing...
The pics (and a little hand porn):
This thing is massive, in person it just dwarfs my 2650. I haven't run it yet, but THANK YOU CASTLE for making this motor. I really wish the Monster Truck versions would come with a shaft suited for a Monster Truck pinion but hopefully future versions will have a 5mm shaft. This should be all the motor we can handle for 1/8th scale.
