dtnel
09.04.2011, 12:42 PM
Where did you get the extra round things for use with tapered screws that help with mounting the bulkhead? I need to order about an extra 12.
I also had a stainless screw snap off in the bulkhead last night so I'm hoping FLM will work with me on it. Do you know if they'll warranty something like that? I've got a lot of money tied up in this and I only have the diffs assembled finally to only probably have To tear one apart now.
I broke it in the process of starting the first round of The build process then Im going to disasaemble it and assemble it using blue threadlock.
I've thought about going all out down the road as you did when I can afford it. Do you have a parts list you can pm or email me?? I'm curious as to how much you have in it minus the rims and anodizing? Pm me if you're willing to It's up to you and I also understand if you choose not to say. You can pm me that if you choose.
cmac
cmac's Avatar
09.04.2011, 12:56 PM
The counter sunk washers are from the RC monster store,
http://www.rc-monster.com/proddetail.php?prod=rcmmbkit
I don't want to even think about how much I spent. I also don't have a total list of all parts. This has been an ongoing process that has taken almost a year. Long before I joined this forum I was already in the planing stages. It all started when I went to 6s with my original Emaxx brushless. Everything was fine with 4s I only had the occasional broken part. When I went to 6s I could not run the truck for more than a few minuets before something was broken. You can ask me about any part I have I will tell you. I just don't have enough time to come up with an entire list. I barely have enough time to work on my truck with my 4year old and 1 year old. I'm ready to complete this project maybe some day down the road I might have the time, but feel free to ask any questions about the truck, if i know or remember where or how much I will tell you. It sounds like your truck is very similar to mine. All you would need are UE a-arms, CVD's and knuckles. A center slipperential and basically you would have my truck.
dtnel
09.04.2011, 03:35 PM
Is that $4 for one of those upper bushings, the tapered one ? If not how many Do they put in ??
You mean these?
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
You mean these? - 09.04.2011, 04:08 PM
Try these out for size.
http://www.fastener-express.com/3mm-...ed-qty-25.aspx
SUPERMAXX YOUR LIFE.
cmac
cmac's Avatar
09.04.2011, 05:18 PM
Yes that is for one washer.
I found the ones from fastener-express after I bought the monster ones. I even had to anodize the two I'm using on the motor mount. So you can see why I don't want to think about how much I spent.
dtnel
09.04.2011, 07:12 PM
Are these about the same thing as the ones that come with the chassis? I did find the silver ones as well.
cmac
cmac's Avatar
09.04.2011, 09:05 PM
The only reason I went with the counter sunk washers is that I thought it would be a nice detail. No real purpose. I just think it looks good.
cmac
cmac's Avatar
09.04.2011, 11:48 PM
I need a 14mm wheel balancer. I have a balancer from dynamite but it's for 17mm hubs. The Hudy tool does not say what size the hubs are only 1/10, 1/8, 1/5th...etc. I don't want to buy one of those only to find out they will not fit. Any suggestions?
Try this
JERRY2KONE
JERRY2KONE's Avatar
Try this - 09.05.2011, 01:29 AM
I purchased a Dubro prop balancer that I was able to setup for 14mm or 17mm. Check out this old thread.
http://www.rc-monster.com/forum/show...HEEL+BALANCING
Also that other link that I provided was for 25 washers per box.
dtnel
09.05.2011, 01:53 AM
I'd say email their support.
Overdriven
Destroyer of Tires
Overdriven's Avatar
09.05.2011, 08:58 AM
Make your own, I did. Mine looks like a bigger version of the dynamite one. I used a few pieces of 1/2 inch tubing (electrical conduit), welded it together (could be bolted instead) and a spare LST/aftershock knuckle and axle I had laying around. I had make my own because most MT tires are too tall and wide, truggy size is the limit for the balancers I've seen available.
cmac
cmac's Avatar
09.05.2011, 09:51 AM
Yes I think I will have to do that.
cmac
cmac's Avatar
09.05.2011, 09:59 AM
Well I just had to take the back half off of the chassis to get the center differential out of the truck( I did not think I was going to have to do that for a while), so I could add another wave spring to it. From one of the other threads it looks like three wave springs is the way to go for heavier trucks. It's now back together, and one half of my tires are glued waiting for them to dry. Does anyone know how long that takes? My carbon fiber turn buckles will have had enough time to cure around 1:00 today, and I will bolt those on, and then all I will have left are the front/rear skids, the front/rear bumpers, the motor, and electronics. Then I can punch the holes into the body. I will post pics soon.
dtnel
09.05.2011, 03:15 PM
Not to sidetrack but I emailed FLM to see if they warranty broken bolts in the hybrid bulkheads. I don't want to buy the rear bulks. I'm going to take a lot more time to build this as I've decided to add a lot more parts after seeing yours.
Try these
JERRY2KONE
JERRY2KONE's Avatar
Try these - 09.05.2011, 03:59 PM
You may want to try using a better grade of machine screw/bolt to avoid having this kind of problem. I have gone through every sort of hardware since getting seriously involved in R/C from stainless steel, to titanium, Tonys screw, Hexhead screws, as well as all grades of black steel screws. The best screws I have found are the grade 12.9 hard steel screws that you can find at a few hardware suppliers around the globe. The link below shows you just some of the screws I now use, and I have yet to strip or break one of these. If you want the best results, then you have to use the best tools and hardware to hold your expensive toy together. Lito turned me on to BoltDepot.com a couple of years ago, and I have not been disapointed yet. I have about $1000 in hardware from them in my R/C storage bins, and I have changed out everything on my trucks using their 12.9 grade screws. Everything looks clean, and everything works the way it should. These are hard steel and if you break these then you are torquing things down way to hard. If so start using a torque screwdriver to measure and torque your connections to the right level.
http://www.boltdepot.com/Metric_sock...m_x_0.5mm.aspx
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
