DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.31.2008, 03:35 AM
In one of the threads around here, I think Patrik actually said that the fan failure was in some instances causing BEC failures.
http://www.rc-monster.com/forum/show...158#post176158
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
jnev
jnev's Avatar
05.31.2008, 01:07 AM
Are you running the MMM in your new buggy MetalMan?
MetalMan
MetalMan's Avatar
05.31.2008, 01:23 AM
It is in my new buggy . Neu 1512 2.5D/F, 4s Lipo, geared 44/18 with 38/11 diffs.
DRIFT_BUGGY
05.31.2008, 04:05 AM
So does this mean it would be better to disconnect the fan from the esc fan and wire it to the battery leads? Would this void the warranty?
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
Electric Dave
05.31.2008, 09:02 AM
I'm pretty sure wiring direct to the battery leads would give the fan too much voltage. It's likely getting 5.5v from the ESC vs 14v+ direct.
lutach
lutach's Avatar
05.31.2008, 11:10 AM
I'm actually running a Novak fan directly from my Rx pack. It would be good to get a cheap 6V BEC and use that to power the fan. In my TC3T, I tried something that I thought I would never do. I actually hooked my fan to the AUX channel on my rx and it works fine and no interference at all.
