08.28.2009, 08:59 AM
Originally Posted by BrianG
What use would a replaceable stator be anyway? I mean, if you remove the stator (and already remove the ends and rotor), you are left with just a cyclindrical shell. I can't imagine the replacement cost of the stator/shell is much more that just a stator...
BrianG if you look at novaks new series it will all make sense. Basically if you were doing a spec class you buy one motor and then just buy a wound stator for the other turns you want. That way you spend about $30 for each different turn instead of $90 a pop for each turn you might need.
http://www.shopatron.com/products/pr...56.56692.0.0.0
Kyosho SC, tekin rs, D3 17.5
Hyper 9e, mmp,tekin 1900kv
08.29.2009, 10:45 AM
Thats.... actually quite cool how you can do that- for racing it makes sense.
Shame it wouldnt be so simple if you fried the stator, as most times the rotor has become demagnetized at the same time due excessive temps- new rotor and stator wouldnt be much cheaper than a whole new motor I think is the point. But for racing, a $30 stator assembly is alot cheaper than a whole new motor in order to change your motor class for racing.
08.31.2009, 12:09 PM
I happen to be in the market for a speedo to go in my B44, and I am running sensored in it because of the smoothness of the novak systems.
What i want to know is, is the Mamba Pro as smooth as the novak systems, and will it play nicely with the novak motors?
I am currently running a 5.5 on a mamba max( I know ), because my old novak wont handle a 5.5.
One if the things that I have noticed is the castle systems seem to have a really low current limitation, the mamba monster is 120, the mamba max is 100, but my XBR is 120 and a GTB is 540, does anyone know if there is a reason behind this or can the novaks just handle more.
Not Bashing Castle I just want a good racing speedo and those are some of the things to consider.
08.31.2009, 12:18 PM
Novak over specs on the AMP rating trying to get people to buy it just because they see a big number on it. Castle rates their ESC n real rating of the MOSFETs. Going by some pictures of the GTB's MOSFET, the ESC is only rated for around 60-90A depending on the MOSFET used. Don't fall for over rated ESC.
2 KiloWatt RACER
08.31.2009, 12:22 PM
Castle list true power numbers, compared to Novak.
dunno about novak motors, but the mamba max runs my sensored based motors nicely with the latest firmware. BTW, I run a 2.5T on the mamba max.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
08.31.2009, 12:31 PM
Basically it boils down to the ratings that they use. MOSFETS have several ratings some are continuous and others are pulsed. The pulsed rating is the higher of the 2. Temp plays a part in it as well that's why there is a derating curve for the Fets. The hotter they get the less efficient and power they can handle. If you look at that I think that Novak rates theirs based on Burst current. If you look at the MMM it's rated at 120A but the burst current was somewhere near 1000A.
I seriously doubt any of the speed controls will handle what they are rated anyway. If you draw 100A at 12V on a MM I doubt it would last more than a few minutes. Same with the MMM If you were to load it at 22V and 120A even with the fan in an A/C room set at 72F it wouldn't last more than half an hour. Granted these things run off of batteries, but to me a continuous rating it just that...
Jeff
08.31.2009, 02:10 PM
Yeah i didnt think that the GTB can really handle 540 amps cont.
My 5.5 runs decently on a mamba max, but not nearly as smooth as it was with a borrowed GTB, obviously because of the sensored, but will the mamba pro be the as smooth though?
Also the mamba gets REALLY hot on a 5.5
Muggy love
08.31.2009, 02:17 PM
I guess all sensored escs are the same "smoothness" (did I spell that right?) :p
08.31.2009, 02:21 PM
I'm probably just overthinking it
Plus i think from the racing side pc programming is a plus, and it is sensored so it should be smooth enough.
What was it someone said about a feature were it raises the kv of the motor?
Something, anything, nothing
08.31.2009, 03:08 PM
Not necessarily true. Firmware and processing speed will still have an effect on the outcome.
The thing about sensors is that they are only useful at 0-low rpm's, once higher emf feedback works better. Castle takes so much type tweaking their firmware I would believe that they will be far superior with the sensored MM Pro as well. Not too mention that it is programmable to a degree not seen on any novak ESC's.
09.01.2009, 03:59 AM
Is the MM pro going to be running cooler than the original MM say in the same setup?
09.01.2009, 07:25 AM
most likely. newer components are usually more efficient...
09.01.2009, 06:43 PM
I agree, but the temps i see on the mamba max after a 5 minute race are extremely hot. I don't know what it is but it just does not like my 5.5. The motor never gets above 150 in 5 minutes, and I have the timing just below average and the start power on high, but it will easily reach 180 or 190 in a race without a fan.
Hopefully the mamba pro is A LOT better with the heat, I plan on buying one, just waiting to see what the initial response is towards them.
09.01.2009, 04:32 AM
Do we have any new updates on release date?
09.01.2009, 09:19 PM
Sounds more like a setup problem than the ESC is bad with heat - I've been running them in all kinds of cars from my lightening 2 buggy, revo conversion, erevo, rustler, and never had heat problems... what's the rest of your setup like? voltage? how many kv is a 5.5?
