Go Back   RC-Monster Forums > Support Forums > Team Tekin
DJ1978
06.19.2008, 07:49 AM
Don't know about the specs.... but based on my conversations with the PREZ of Tekin, I know he is determined not to have a disasterous debut like the Monster Max. They are testing in a lot of different vehicles, Pushing them to extreme limits to assure they perform the way we expect them to. They have made it very well known they are testing in race and bashing conditions in the vehicles we want to use them in to assure the durability necessary to support this great new class of vehicles.
Mister-T
06.19.2008, 03:47 PM
Castle did test the Monster max too... But they can't prevent a batch of microchip going bad after XX minutes. They manufacture the ESC but they are not inside :P
Sower
Sower's Avatar
06.19.2008, 03:50 PM
Good point - the situation with the MMM had nothing to do with a lack of in house testing. It was strictly a batch of bad parts from a supplier and not on every unit. Tough deal for CC but it happens to the best of them and could happen to Tekin too really. I hope it won't, but it sure could.
MBX6T Tekin RX8 5s Neuenergy
www.robsower.com
Happywing
06.20.2008, 07:16 AM
The key words here is "house testing." CC claims they did plenty of house testing. Tekin is testing on the track...big difference. A debacle of CC/MMM proportions will not happen with the new Tekin controller. Their testing has been much more thorough. They also got a scare from the abysmal failure of the MMM.
Sower
Sower's Avatar
06.20.2008, 10:35 AM
That's all well and good, but what happened at CC could happen to Tekin and has nothing to do with testing. The fact is that a certain number of controllers got a bad part. The rest didn't. Would you expect them to test all the controllers after production for 2+ hours of race conditions to make sure they're ok? The MMM I have has gone through several hours of racing and performed flawlessly.
Bottom line is that manufacturers rely on the parts of their suppliers. That has nothing to do with previous testing.
www.robsower.com
DJ1978
06.20.2008, 10:55 AM
I am sorry...but the failures that racers are seeing show that not enough testing was done within the parameters that the ESC was going to see in the real world.
I don't know of one fan that has not failed or broken
upon impact from the jumps with the 1/8th scale buggies and truggies, the case compresses and damages wires from the fan and shorts the whole ESC out. There is not enough clearance between the bottom of the case and the plug of the fan. It has been breaking off. The fan blades catch on the housing of the fan and break off. Not to mention the electronic failures that have frustrated owners to the point that I have had some tell me they don't even want to open theirs and put it in their vehicle.
Some, like happywing did not even get to put his vehicle on the track. It toasted when he was setting it up in his basement.
I would be curious to know the actual failure numbers of the intial release.
lutach
lutach's Avatar
06.20.2008, 11:38 AM
The real reason for having other people test the controller is basically motors choices. Not everyone runs a Neu 1512 or 1515. Some run Mega, Plettenberg, Lehner, Hacker, Feigaos Type L/XL and larger 1521/1527 Neus. A company can say their controller can handle any motor, but how can they back that up. Are they just going by the AMP rating on the controller? Racers only race for a few minutes, while some one who is in the hobby just to have fun will probably bash with some friends for hours. Having team drivers test stuff out is good, but it would be good to have somebody that owns various motors do some test as well.
Sower
Sower's Avatar
06.20.2008, 12:02 PM
Good point - do we know for sure they didn't test on those other motors?
www.robsower.com
lutach
lutach's Avatar
06.20.2008, 12:09 PM
They do say things like that in rctech . All I here them saying is how great it is with a 1512 or a 1515, but mostly 1512 motors.
Sower
Sower's Avatar
06.20.2008, 12:00 PM
Well the first thing I would like to mention is that my MMM works perfectly and has for several hours. This last weekend I ran three 5 minute qualifiers and then the 15 minute main with no problems at all. Fan works, temps under 120, blah, blah, blah. It was incredible! Remember, when things work great you don't hear about them as much as when there's a problem.
The other thing I would say is to be careful about pointing fingers at CC unless you have first hand knowledge of what they do or don't do in their testing. Your judgement can be damaging to their reputation and should be given careful scrutiny. CC has proven they are a great company and puts out great products with great service.
www.robsower.com
DJ1978
06.20.2008, 12:15 PM
You are right. I know CC is a great company with excellent 1/10th and mini products and they have
excellent customer service.
If you have one that is running.. that is great.. LXMUFF has one that is running too.. but he as worked to protect all the areas that have failed on others.
I don't have first hand knowledge of their testing system... but let's be honest... if you were looking for a Monster ESC.. based on the posts you read and experience of friends and post of CC reps themselves... would you choose one right now?
I don't want to get in spitting match. In my opinion, the initial launch of parts had a lot of flaws.
I am sure they are working hard to fix them as fast as they can.
I am looking forward to seeing the next generation..
I am also looking forward to the TEKIN ESC so we have more excellent choices
Sower
Sower's Avatar
06.20.2008, 12:20 PM
Fair question, and I would probably still go with the MMM. I've had the MGM and it's great but I like the programmability of the MMM as well as the "feel" of it while driving. I believe the MGM was much more efficient though since it was brushless only. Liked it's mounting and packaging better too. I see your point though and I think it's valid. There's not a lot to choose from right now.
I am looking forward to Tekin's release too and have seen them testing it here at our track with nice results on 4s. I think they will have a great product. I also feel that when CC gets the right parts installed their ESC will be great for 80% of the people wanting to get into brushless without spending $300 on the ESC alone.
www.robsower.com
Happywing
06.20.2008, 04:55 PM
Why be careful? Opinions on a forum are not going to damage their reputation. If anything has caused any damage, it's the MMM itself. We have a large group of conversion guys around here and we know what works/what doesn't. It's very clear to us that CC did not do their homework. No, we don't know how they did their testing. Whatever they did though, was not enough. Nobody's making up these stories about failures and for the most part, people have been very understanding. I don't know why everyone's so careful about being critical. I know CC has been a great company to us all and we're giving them a free pass on this one. Still, you can call the MMM what it is at this point...a big disappointment.
phatmonk
RC carbon junkie
phatmonk's Avatar
06.20.2008, 05:08 PM
So when will we see this 1/8 controler from Tekin.After you have driven Nitro then crossed over to Brushless you never want to go back.How long is it going to take to offer a reliable controler that can take the punishment.This 1/8 Brushless market is going to explode and whoever can design a Speed control that will stand the test of time is going to be be considered the golden standard = to companies like Neu.I have been checking the Tekin website for any info on the r1mt and the link is gone.I hope they havent decide to pull away from this 1/8 controler market.I have heard alot of good thing about Tekin.
Sower
Sower's Avatar
06.23.2008, 10:13 AM
I think you and I will have to just agree to disagree. I think people should always be careful about what they say - forum or not. Now if there's something of value that is solution based, great. If not, I really don't see the point in this type of gossip, and yeah, I do feel it can be damaging.
And this whole idea that CC hasn't "done their homework" or didn't test enough . . . please tell me how more homework or testing would have solved the problem of getting some bad parts.
All I can say is that I know what works and doesn't work and my MMM is working perfectly with my Neu 1515 & 6s 3900
www.robsower.com
