jhautz, too late. I already replaced the caps. I did a preliminary install on the esc and the zip appears to be back. When I hit the throttle, it winds right up and balloons the tires.
The caps that we got, however, are taller than the stock caps. It will just barely fit into the case. I decided to do a couple of "upgrades" anyway. I'm going to wire it all up and take it out to the track to see what happens.
Some pics...
I added the 5.5mm connectors because it will give me a good base for the additon of the cap bank and I like the idea of being able to replace the battery leads without having to tear everything apart to get to them.
I am, however, a bit concerned about the weight of those connectors on the pcb. Being banged around in the track may prove to be too much for the pcb to stand. I'm going to try to reinforce them somehow. If I can't come up with a satisfactory way to do that, the connectors are going to have to come off.
I also have to say that replacing the caps was a snap. It literally took me a couple of minutes, after I had the esc apart.
ZPB, I used arctic alumina. No homemade stuff for this application.
I did save all of the stock parts. That way, if all is not well, I can just put it back to the way it was and send it back.
