Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
12.29.2007, 01:52 AM
It's actually Chrome Nail Polish. I hand picked it from this huge bag of little bottles that my daughter's have collected.
Naw, I won't be doing my nails.
I prefer that "Manly" look.
Ahh, the "manly" look, when was the last time you took a shower? Dirty = manly! If that is true I am only manly when I come home from work!
johnrobholmes
johnrobholmes's Avatar
01.20.2008, 02:28 AM
Will you charge and balance those as a 6s pack? Do you use velcro to hold them down?
sikeston34m
sikeston34m's Avatar
01.20.2008, 08:17 AM
I charge them as 3S packs.
Yes there is Velcro in there.
team3six
Just a guy with a box of crayon's
team3six's Avatar
Some advice, You should get some electric goo to cover up the bare wires between the caps. You will loose alot of resistance in that.
It's not just paint! It's an Attitude!
www.team3sixrc.com
sikeston34m
01.20.2008, 08:18 AM
Bare Wires? Where's a Bare Wire? LOL
01.20.2008, 02:48 PM
Hey Sike, glad that the quark is working out for you.
Are the diffs holding up better for you with the better bearings?
The teflon washers are the ones I use to shim up the axles, usually one does the job!
About the bare wire thing, you guys are joking right? I can't see the rubber coating lowering the resistance, maybe I am missing something?
sikeston34m
01.20.2008, 07:14 PM
I'm uploading Video's to Youtube right now. I'll post vids in a few minutes. You're gonna think this belongs on "beat your truck" or something. LOL
The Diffs held up great through the first run, and ummmmm well.........15 minutes into this run, the rear pinion bearings went out. The gears sounded like they were munching on balls.
I'm not sure what to do at this point. The 10/43 gears won't and don't hold up to this kind of power. The spiral cut loads the pinion bearing like a thrust bearing. Even the Ceramic Nitride bearings can't take it.
I might go with the 13/43 straight cut gears and try again. They will tend to side load the bearing instead of loading it like the spiral cut gears are doing. This custom Wye Wind starts better and makes more torque, so I think I still have a shot at it even with the 3.3:1 ratio.
Somebody show me a Diff that can stand it and I can make the power to shove through it. LOL
01.20.2008, 07:20 PM
Sounds like it is time for a needle rooler bearing, not sure if you could find one that is the correct length to replace both of the stock bearings. You would need to have the diff cases machined to remove the two raised portinos that hold the std bearings in place. I vaugely remember that a needle bearing will hold up better than a ball bearing will, in a situation where there is alot of side loading. Sounds like the races are just getting hammered and falling apart.
I have a feeling that the hpi baja diff will be able to handle your outrunner, but it may not fit in the revo very well!
sikeston34m
01.20.2008, 07:26 PM
A Needle Type Thrust bearing would be ideal! Problem is, I don't think anyone makes them in this size.
I just charged the Batteries back up. 15 minutes of running like this on 6S used 2182mah according to my MRC Superbrain 989. This setup would run HARD for over 30 minutes before it hit the cutout.
Dang Dang. What to do? LOL
I'll have to check that diff out Linc.
What kind of diffs do those 1/5th scale Firehammer's have in them?
johnrobholmes
01.20.2008, 11:19 AM
You know you loose a lot of resistance with bare wire. I hear that if you have enough exposed wire, you can have a superconductor!
sikeston34m
01.20.2008, 07:18 PM
OMG That's Hilarious!
crazyjr
crazyjr's Avatar
01.20.2008, 01:30 PM
Sike, Do you run the Novak cap on the battery/esc wires? What exactly does it do to help?
01.20.2008, 01:40 PM
You hook it up as close to the esc as possible, located on the battery wires. It helps to reduce esc operating temps by at least 10-15*, and also helps to absorb voltage spikes from the esc > batteries. It can also help to smooth out power delivery from the batteries, by providing a steady current from the caps so that the batteries arent overdrawn during heavy load situations. or something along those lines; all I know is I added an extra novak cap to my hvmaxx and it helps smooth things out no-end, especially towards the end of the run when the batteries drop-off.
sikeston34m
01.20.2008, 07:16 PM
Very good description Neil!
johnrobholmes
01.20.2008, 07:40 PM
Awesome! That motor just tosses the rig around! You got lucky many times on the rollover, almost 90% recovery rate back to the tires!
Who else wants to see sike take those dirt piles like a set of doubles?
