Maciolus
09.29.2008, 10:28 AM
Originally Posted by Unsullied_Spy View Post
Do you need to cover up the holes in the motor? I've got a RC-M heatsink clamp with a trimmed washer on mine but haven't run it yet.
I use lathed Mike's front NEU cover to protect front of the motor and insulating tape on the rear.
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
09.29.2008, 11:56 AM
Anyone have temps from running stock, and then again after the holes are covered up? I'd imagine there would be some rise in temps covering them. Instead of using tape on the rear, how about some metal screen instead? Would keep the larger stuff out yet allow air to circulate. Of course, some dust would get in there, but it's the big stuff that's a problem...
10.02.2008, 02:31 PM
Who likes good news:
Sent: Thursday, October 02, 2008 2:20 PM
To: info@medusaproducts.com
Subject: 70mm Medusa motors
Hi there. Just curious if there was any news on the up-coming 70mm V2 medusa motors. Last I heard they were due late september, but Im guessing the sudden popularity of the 60mm versions amongst r/c truck owners has pushed back the eta somewhat. Any info is greatfully received.
Yours sincerely, Neil Ward.
Neil,
No, just other delays in getting parts for the prototypes and then testing pushed it back some.
We’ve tested our prototypes and all is well. Production is now gearing up and we expect to have some late October.
Shortly all the motor info will be added to our web pages with pre-orders being accepted.
Regards,
Jeff Little
Medusa Research, Inc.
Engineered Products for the RC Enthusiast
Yay!
Buzzsaw46
10.02.2008, 02:35 PM
That is some good news! Cant wait to see what KV's they will have.
lutach
lutach's Avatar
10.02.2008, 03:16 PM
First prototypes will be 1600Kv.
10.02.2008, 03:30 PM
Bit low for me, I'll hold out for something in 1800-1900kv flavour. Im curious though, all other things being equal, how much more 'power' (torque I guess) would a 4 pole motor generate compared to a 2 pole? Maybe I could just gear up a slower motor, but then I'd worry about my batts maybe.. gah.
JaySki
JaySki's Avatar
I just soldered up some wires for the Medusa 36-60-2000...
I have it geared at 20/58 in an e-revo and with 4S looks like it'll be around 35-37ish.
What gearing would be a good start for 6S? Speeds show mid 50s with RPM around 45K.
I'd like to use the 2X3S packs I have.. but I don't care to blow another MMM as I did with the NEU 1515 1.5D.
lutach
lutach's Avatar
10.02.2008, 03:36 PM
The 4 pole will basically in theory make 2 time the torque and you can gear up the lower Kv with 4S lipos.
10.02.2008, 06:17 PM
Depends what speed you are looking for with the 6s setup. I'd say aim for 40-45 as a nice speed, the calculator will tell you the required gearing. I doubt the MMM will blow due to using 6s with that particular motor, vs the neu which is alot more amp hungry by comparison.
As for 2pole vs 4pole torque, thats kinda what I figured, just seems a little too straight forward for my cynical mind.
asheck
10.02.2008, 06:27 PM
I'm betting with the MMM it will be a little faster.Mine ran 44 with my Quark 80 with 68/24 gears(40 with a MM) 20/58 is just a little lower,in my Emaxx with a MM 20/58 it runs 39.But thats with dirt bonz that don't expand much.So don't be surprised if that gearing gets mid 40's. On 6s I hit 55.7 with 24/68 gears.
Buzzsaw46
10.03.2008, 04:08 PM
Yep, till the HV MM shows up
10.03.2008, 05:38 PM
Wire my batts in series instead of parallel, but I'd need something in the ~1000kv range then, rather than 1600kv. Too many possibilites...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
10.03.2008, 06:21 PM
Not quite 2 times more. It should have the same gross torque per phase but the RMS torque output will be higher because there are 2 times more pulses per revolution.
MetalMan
MetalMan's Avatar
10.04.2008, 12:41 AM
I just received a 36-60 1600 from Mike today. This will be going into a Jammin' X1-CRT with X1-CR center diff and Mike's CR motor mount. The original plan was to run 6s Lipo geared 12/46, but Mike's mount doesn't allow anything smaller than a 14t pinion to mesh. That means I'll be running 14/46 and 5s Lipo instead. I hope this motor works out!
sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
10.06.2008, 08:46 AM
Mmmmmm. That should go just perfect with my setups. I'm thinking that will be pretty awesome in my hyper 7. Looks like another item I'll have to pre-order.
