Jahay
07.07.2010, 09:11 AM
mckrill the gorilla tape i have just used to belt my bad land tyres and my large MOAB tyres is amazing!!! Very little but even tyre ballooning for perfect contact with the ground! You should defintiely use it!
mckrill
Technology Explorer
07.07.2010, 09:34 AM
OK, I will do as you say - any ideas for were to get it easily and fast? In Europe is even better..
mckrill
Technology Explorer
07.07.2010, 09:42 AM
Crazy - I found a supplier in a small village 50km from were I live. He had 3 rolls on stock.
This frigging Internet makes you search all over the world for stuff, except in your own neighborhood..
Jahay
07.07.2010, 09:49 AM
This is UK Ebay - http://cgi.ebay.co.uk/GORILLA-GLUE-T...7#ht_937wt_911
Make sure you get the 48mm wide version.
When i installed i did two complete wraps to make sure it was clean. But before sticking it, i cleaned the tyre with alcohol to remove any dirt.
brian015
brian015's Avatar
07.07.2010, 10:00 AM
warm it up with a hairdryer after laying it down to make sure adhesive is good and stuck - at least that's what I do
Jahay
07.07.2010, 10:03 AM
hmmmm gd idea... i would have done that if ithought of it... But so far so good...
mckrill
Technology Explorer
07.07.2010, 10:09 AM
Hey, thanks! With some luck there will be some full speed testing this weekend!
mckrill
Technology Explorer
07.09.2010, 02:47 PM
I got the Gorilla Tape today and picked up some more wheels as I used for belting with the Tesa Duct tape - I hope for a difference to the better.
I'm also doing a complete haul over of all moving parts in the car, including the diffs, bearings etc. Hope to be up and running again within a day or two..
mckrill
Technology Explorer
07.14.2010, 03:36 AM
This morning I finally received the micro pumps and the coolers
tc3_racer_001
tc3_racer_001's Avatar
07.14.2010, 03:40 AM
isnt the truck heavy enough :P looks awesome!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
mckrill
Technology Explorer
07.14.2010, 03:53 AM
This stuff is amazingly light, the truck is 13 pounds / 6kg ready to run, not bad considering a 14s set-up
mckrill
Technology Explorer
07.14.2010, 03:57 AM
The large radiator + pump is 50gm /1.8oz, the two small radiators + pump is 38gm / 1.3oz. Tubing and coolant I have no idea yet..
Jahay
07.14.2010, 05:23 AM
haha that looks so kl!!! very interested to see how this will all work...
mckrill
Technology Explorer
07.14.2010, 06:20 AM
I also painted the Willys Jeep body yesterday:
Right now I have to find out a way to safely secure the radiator and pump to the shassie.. There are no mounting holes or brackets - so back to the work shop.
Jahay
07.14.2010, 06:28 AM
You are putting a lot in your chassis... its a shame is basically stock length, otherwise you could have plenty of space in there if it was a little longer. I doubt your truck is 14lbs any longer with those big wheels and tyres.... but who cares when you are running 14s!
Did you use the gorilla tape on those tyres?
