03.25.2008, 06:05 PM
Originally Posted by kingiggy262 View Post
I use the FMA direct Cellpro 10s charger. This is an excellent charger!
http://www.fmadirect.com/new_applica...0s_charger.htm
Wow, just checked that out and it looks like a really nice charger! 10s, 10A, 300w, built-in balancer, and the really neat feature that throttles down the charge rate according to your power supply current capability (nice!).
Is there some type of online manual or something I can peruse? I'd like to have multi-pack memory settings and the ability to set CC/CV threshold. And I'd like to know how the balancer plug setup works...
83gt
03.25.2008, 06:16 PM
I know it's different on the 10s, but the 4s charged directly through the balance plug, and charged each cell by itself completely independent. I've seen as much as a 3c charge rate on my 4s, but it never lets the pack get even warm. Nifty.
Here is the manual on the 10s. It's on my shopping list just as soon as budget allows.
http://www.fmadirect.com/support_docs/item_1258.pdf
J>
03.25.2008, 06:33 PM
Yeah, I don't particularly like charging high currents through the balance taps as they aren't designed for that kind of current flow, but from I gather, the FMA 10s charger works like most of today's chargers: main charge current goes through the main leads and the balance connector is used for balancing and cell monitoring...
azjc
03.25.2008, 07:12 PM
thats how the Flightpower V balancer works
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
03.25.2008, 07:32 PM
1210i and LBA10.
:D
kingiggy262
BL-Revo
03.25.2008, 09:06 PM
Yep, it charges through the main leads and balances through the balance connector. You can charge only through the balance connector but it will be limited to 4 amps max charge compared to 10 amps with the main leads. When charging you plug in the main leads from the battery to the charger and also the balance connector to the charger at the same time. During charging it will tell you the amount of maH put back in along with the internal resistance of each cell and the current charge rate.
I am still waiting for the PC interface cable so that I can view all the information while charging and even change settings on the fly from the computer. I have only had this thing for one day and so far I am really pleased with my purchase!
For a DC power supply I am just using a normal PC power supply that I had from an old computer and then installed banana jacks. It can output up to 25 amps so it has no problem supplying enough amps for charging.
VintageMA
VintageMA's Avatar
03.25.2008, 10:25 PM
MRC 989 chager and TP-205V balancer.
“Everyone has a right to be stupid; some people just abuse the privilege.”
