Originally Posted by RC-Monster Mike
There are a few store links throughout the forums, actually. Should be easy enough to add more. :)
MoFo - the 8 mounts work for the buggy and the truggy. Our battery trays are kits, and we offer a couple sizes to fit whichever battery you have or plan to use. You should be able to find plenty of pictures for the mods, but basically you cut the radio tray behind the steering servo. The battery box box mounting is described in the listing as well. With one of our hardened pinions, you simply use the stock spur gear. :)
Cheers mike, i have emailed you with same question & requst for a total price including p&p to the UK, before you posted this reply, i'd figured i'd need the motor mount, battery holder & pinion, just was unsure what else apart from obvious motor/esc was required......
I'd like to run a Neu motor, and probably the MMM, so im open to battery advice, i assume im looking at a high capacity 4s ? for nitro like speed & good runtimes ?
