04.10.2008, 09:08 AM
I think you'd have to take off the heatsink and/or control board to get visibility to the fets - only alternative is to send to castle...
tashpop
04.10.2008, 09:11 AM
since getting into the brushless scene, i've noticed on several occasions that when i'm getting unusual cogging and/or heat with a planned out system ive always had problems with my motor connections. i've also heard mamba's like to have a really solid connection to the motor's. i would try going back to you're first gearing and solder the motor direct to your new esc. another possibility is its just a bad motor. i've had one of those too, my first feigao.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
xcntrk
xcntrk's Avatar
04.10.2008, 01:31 PM
Thanks… I wouldn’t be surprised if the motor was bad. Afterall with the first gearing setup it was subjecting to above 200F temps. I spins over freely and there’s no shaft play, but other than that I’m not sure how to investigate a bad motor.
As for the cogging; maybe the wire that ultimately pulled free from the board was causing a poor connection. Perhaps I took a tumble or something that left this wire just barely hanging on and caused a poor connection leading to overheating and ultimately the loose wire?
As for motor connections, they’re very solid. I’m using the CC 6.5mm plugs (the biggest ones) on both ends then a full chunk of heat-shrink over the entire connector. I squeezed nearly 3-inches of solder into each plug so they’re definitely secure!
Tmaxx BL Conversion
Hyper-7 Truggy
E-Slayer
