05.05.2008, 03:34 PM
If I was to set the lvc, 2v per cell correct? Also just got a used hypersonic charger, and wanted to know if anyone knows how to wire the balancer cable? A stock hitec servo plug will fit, just need to know where the balnce wire goes. I see that the 2s packs only have 1 balance wire, and the 3s packs have 2. But the input has 3 pins on the charger. Any ideas?
05.05.2008, 03:47 PM
No drawings on site but think you can tell from these pics...
White at 3.3v
http://a123racing.com/a123popups/popup_2s1p.html
Guess on 3s but would guess white 3.3, red 6.6
http://a123racing.com/a123popups/popup_3s1p.html
snellemin
2 KiloWatt RACER
snellemin's Avatar
The middle pin is used for 2s packs, with the balance wire connected between the first and second pack.
The outer pins are used for 3s packs. The 1st pin is connected between the first and second battery, and the 3rd pin is connected between the second and third battery. If you connect it backwards, it won't charge. Nothing will blow.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
05.05.2008, 04:16 PM
Ok, so on a 2s pack, the wire goes in the middle of the plug, and on a 3s pack the wires go on the outside pins. Which way do the 3s wires go? Would the balance wire between the 1st and 2nd cell go on the left side (fuse side) or the right side(led side)?
Many thanks, as I have a 2s pack charging at the moment!
snellemin
2 KiloWatt RACER
snellemin's Avatar
05.05.2008, 04:58 PM
It would go to the fuse side.
05.05.2008, 06:55 PM
Thanks Romano, I appreciate it! Got all of the batteries charged, now just have to wait on the diff parts I exploded to try the a123 cells out!
kulangflow
Never Fast Enough
kulangflow's Avatar
05.07.2008, 05:30 AM
10 cells - They peak at 3.6v hence 36v
I bought three packs and stripped them down partially - I used all the existing tabs... Layout of the cells isn't perfect but made life easier.
The DeWalt 28V packs have 8 a123 cells also. Just buy three of them to get the 24 cells you'll need for 2 x 6s2p.
Sammus
Sammus's Avatar
05.07.2008, 06:22 AM
I heard DW aren't using A123 cells anymore... anyone confirmed this yet?
kulangflow
Never Fast Enough
kulangflow's Avatar
05.07.2008, 10:27 AM
JohnRobHolmes confirmed that the newest DeWalt packs will no longer have a123 cells. There isn't any immediate way to know which packs are "new" and which are "old".
aqwut
Brushless Heavy Weight....
aqwut's Avatar
05.07.2008, 11:09 AM
that just sucks big time... I was about to get some more... so what will they be using?...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.07.2008, 11:24 AM
So they buy cheaper cells and sell the packs at the same price.......nice!
www.cubicle101.com
kulangflow
Never Fast Enough
kulangflow's Avatar
05.07.2008, 11:58 AM
Here's the thread with the details.
Start at post #15.
Sammus
Sammus's Avatar
05.07.2008, 05:41 PM
I personally probably wouldn't recommend someone go and by 3 packs to get a123 cells then without mentioning that :)
kulangflow
Never Fast Enough
kulangflow's Avatar
05.07.2008, 06:04 PM
Yeah, good call. I guess the first line should have read, "Some of the DeWalt 28V packs ..." or something like that.
Brain fart on my part. Apologies.
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
05.07.2008, 06:20 PM
So is a cut off voltage of 2v per cell fine for A123?
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
