Papa
Papa's Avatar
09.19.2005, 08:36 PM
Found this quote on another forum:
It’s best to reset the EPA with the programmer to maintain maximum resolution, but turning down the EPA will work.
Mike Mayberry
Product Development Manager
Team Manager
Hitec/Multiplex USA
Waxxxymunkee
I've learned so much here
Waxxxymunkee's Avatar
09.19.2005, 09:30 PM
Well I have the Futaba PCM I hope that helps im still learning this controller :M:
" If you hear me coming I did not do my job right "
Nick
COOKIES!
Nick's Avatar
09.20.2005, 03:13 AM
Right, I'm thinking of just getting the Bluebird, as I don't think I will get much more without spending annother £20 or so.
Here it is:
http://www.modelsport.co.uk/?CallFun...n&ItemID=23068
Also, what power supply does the UBEC give to the servo? 6V? Does this not drain the batteries quick = less runtime?
~ Nick.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
09.20.2005, 06:13 AM
I have those servos as well(listed with no picture). I don't think you will get more for the price, but it is no comparison to the TG servo this post was talking about.
Nick
COOKIES!
Nick's Avatar
09.20.2005, 12:14 PM
Yeh, I would probably go for a more expensive option but I need a new servo this week and I can't afford fast internation delivery.
Sorry.
~ Nick.
coolhandcountry
coolhandcountry's Avatar
09.20.2005, 06:09 PM
You won't see a difference in run time nick. It is 6v to the servos.
If the supply falls below 6v it goes to bypass.
Peace!
Country
Help support the
Rc-Monster
Buy here
tyrewq
10.22.2005, 04:04 AM
on a slightly different topic. i got an emaxx with hs-645mg servo. it works fine but after a while the screw that link the servo gear to the steering handle loosens up and i have to tighten it back to steer again. is this the original intent of the design so the servo won't be damage by hard hits or turns(hitting objects at an angle)? should i buy another servo or steering gears/handle?
is there also an all metal alloy servo available for the emaxx? i thought hs645mg was all metal but when i open it it has one plastic gear and the rest metal.
Basketti
10.22.2005, 05:06 AM
I have the hs-645 servo on my stock emaxx, it has one of those spring servo horns and it works ok but i just put on some aluminum beadlocks with jumbo claw dawgs on it and it winds the spring alot lol so i'll change the wheels back to something else. im gonna save up for the 333oz servo for my aluminum e-maxx. I thought i might aswell cause after i get that i'll never need another one, and i'll get the supermaxx servo saver :)
rctruckz
11.03.2005, 04:41 PM
645's were used alot in large scale gas (such as FG models) a problem some people had was the EPA... default factory settings were set at 100%..if you your steering jammed for whatever reason then it caused the servo to burn-out, a way around this was to set the EPA (End Point Adjustment) to about 90%
Anywayz back onto topic!
I use Multiplex servos (big red things), no probs with them so far & the torque is very nice, can turn my 1/6 FG MB wheels full lock & very quick while stationary :-)
