Originally Posted by lutach
So what is the average (Or best) final drive ratio that we can have to determine the right motor for our application? Most of my vehicles are geared for 15+ final ratio now and everything is working good. Speed is around 39-40mph.
Lutach - I read a thread on another "reliable" forum (can't remember which) about a year ago by a really hardcore 1/10 on-road guy who was describing how the final drive ratio should be 1:1 with the rollout of the tires for highest efficiency of the setup.
I blew this off originally and didn't think much of the logic behind it - probably at the time because we were all setting up our systems for 30-35k rpm to "match" the equivalent speed of the nitro that would have been in the system originally and that was what most motors could handle before overheating too much.
Using the RC-Calculations page you can find this ratio easily by looking at the fields for "Total Reduction Ratio" and "Tire Circumference". If the two numbers match then you ratio is 1:1. If the rollout is 15" and the total ratio is 10, then the number is 15/10=1.5.
This makes sense if you think about it for a while because if you increase the size of the diameter of your tires, you have to reduce the size of the pinion to make up for it. And MTs with larger tires have a higher total reduction than buggies with smaller wheels.
I also came across an article within the past week or two that eluded to this same concept that was talking about the way people are setting up their vehicles lately. It is hard to get a true 1:1 ratio and usually it is closer to 1.25, but lately people are gearing closer to 1.5 and even approaching 2 at times - and this is leading to much more heat being generated in the setups.
Another way I came up with looking at this is that you should setup your system for 1" of travel for every 1 revolution of the motor.
Here's how I am going to test this and Brian's theory on faster motor speeds on the Neu on my CRT.5.
I just got a 1509/2Y (1820kv) for my CRT.5 and have been running it at 15/46 on 5S with ProLine 30 series wheels and tires. The specs for this setup are:
Tire diameter = 4.1"
Motor RPM = 33670 (@3.7 v/cell)
Total Reduction Ratio = 9.97
Tire Circ. = 12.88
Est. Top Speed = 41.21mph
Ratio = 12.88 / 9.97 = 1.29
This is a very cool setup and runs awesome.
I am going to setup this system to run with 6S and push the motor rpms up to 40400.
To compensate and also to get the rollout/gearing ratio closet to 1:1 I will run a 13/46 setup with the following:
Motor RPM = 40400 (@3.7 v/cell)
Total Reduction Ratio = 11.5
Tire Circ. = 12.88
Est. Top Speed = 42.85mph
Ratio = 12.88 / 11.5 = 1.12
Everything will be well within comfortable specs of operation. I have already run the 5S setup and will run the 6S setup tomorrow after work for a bit and report back on performance, smootheness, acceleration, temps, etc.
I have come to the conclusion that for the weight of the vehicle and size of the tires it take about 800-900 watts of power to push the truck the way I like it - so I don't expect that to change to much - it has been pretty consistent with 3S 4S and 5S setups. The question will be if the 6S and faster motor speed is better.
