RC carbon junkie
06.19.2008, 05:36 PM
So does that mean that the MMM will be replaced with new units or do we get the MMM that we sent in.
I don't understand, but I don't think I like it.
06.19.2008, 08:57 PM
Originally Posted by TexasSP
Am I correct in assuming that we who have had ours in for repair will get the first ones off the production lines then you will start filling orders Patrick?
This is what I was asking in post #12 of this thread, I guess it got over-looked. I was wondering because I liked the wires on the ESC instead of the bullets. I'm kinda scared that it will end up being a problem like the VXL ESCs.
RC carbon junkie
06.20.2008, 04:44 PM
I hope if the units are new they supply new 5.5 mm connectors and my power supply connectors  I also just talked to Castle and she told me 1 month since the units need to be retooled or rebuilt.So I will be soldering the BEC onto my new MM so I can run my 8T.I sold 2 MM to buy the 1st MMM.I should have kept them.
06.23.2008, 10:36 AM
The VXL ESCs use a bullet that is surface mounted on the ESC -- the bullets we use are through-hole, and are MUCH larger diameter than the VXL bullets so they are significantly stronger.
Patrick del Castillo
President, Principle Engineer
06.23.2008, 10:36 PM
Good question. Patrick, do you know?
Yip Yip Yip...
06.23.2008, 11:21 PM
Originally Posted by Pdelcast
It means you are waiting on the new ones. Sorry about that - - but you will get high reliability out of the new controller.
There is your answer
And from another thread
Nope, probably be mid to late July. Sorry, we are working on it as fast as possible.
Something, anything, nothing
06.19.2008, 05:59 PM
06.23.2008, 11:05 AM
Hey Patrick: You guys have my MMM for the second time (no regulator output). I got the post card you send that says something to the effect of "we got your stuff & will repair it soon". Does that mean your going to fix it & return it or am I waiting for the new ones to get built?
Thanks
Mike
06.23.2008, 11:22 AM
So... If I have a first gen MMM that is still running, Can I send it in to get the Improved chip installed? Id rather have an ESC I can count on rather than just waiting for the day it finially goes.
to make it...
or break it...
Silent...But Deadly
06.23.2008, 11:33 AM
We will give priority to those who have a bad chip -- but yes, we will replace with a new version if you wish.
I have no idea what's going on
06.23.2008, 12:52 PM
Cool, that's good to hear! I have an MMM which I've still not even powered up yet (waiting to finish the truck it's going in), so I think I'll send it back at some point before it's used and get it replaced with the new version if that's ok. Like Jhautz, I'd like to have an MMM that I *know* isn't going to stop dead at any time.
06.23.2008, 05:35 PM
Top notch.  At this point I have 2 fully functioning MMM units in my buggy and truggy (with the exception of the fans being run off of the Rx rather than the MMM board cuz the little white plugs broke off of the board) and a 3rd that was going to go in a Savage, but to this point has been riding around in my pit box just incase.
Once you guys get caught up I will probably send them in for the upgrade.
to make it...
or break it...
Silent...But Deadly
06.23.2008, 06:50 PM
This is why I chose to jump in with both feet and buy the "first batch" of controllers. I expected Castle Creations to take care of its customers and they are doing that.
My Monster ESC worked great this weekend although it was only used in three 5 minute qualifiers and a 5 minute main. The testing/fun will continue.
Supermaxx
06.24.2008, 12:53 AM
That's great to hear. I'd rather have the pece of mind with the new and improved ESC  .
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
06.23.2008, 11:32 AM
Thanks
Mike
