MetalMan
MetalMan's Avatar
09.30.2005, 07:13 PM
Do you guys have a picture of the "STP"s? Their site doesn't have a very good one, and this seems interesting.
Gustav
Gustav's Avatar
09.30.2005, 07:57 PM
You can see Starscream's in this thread:http://www.rc-monster.com/forum/show...=&threadid=441
Basically,the 2 end caps compress the cells together using some threaded rod and some spoke nipples.
They sell silver paste seperately which you brush on the cells to lower the resistance further.
Their race packs use the same end caps as the standard SPT kits/packs exept they use different contacts to make the pack slightly shorter for fitting in touring cars and such like.Same end cap though.I got the standard,i think its better unless you need it to be a few mm shorter.
Serum
Serum's Avatar
10.01.2005, 08:22 AM
Getting soldered inline packs from eachother is a pita, some people brake them loose, i had an idea to use a thin metal wire and use it as a saw, to cut them loose.. Tin is not the hardest material available, i'm sure it cuts like butter.
That HB lightning kit might be available some time i've got some plans cooking..
