emaxxracer15
RC-Monster Maxx
emaxxracer15's Avatar
10.03.2008, 06:15 PM
is the copper braid that connects the cells just that stuff that is used on slot cars? something like this, 'cause i am having a hard time finding anything else.
BL FLM E-Maxx (thread here)
MM rustler
kulangflow
Never Fast Enough
kulangflow's Avatar
10.03.2008, 06:40 PM
This will work too.
JThiessen
JThiessen's Avatar
10.03.2008, 07:42 PM
I got mine at radio shack
Sammus
Sammus's Avatar
10.03.2008, 08:25 PM
you would be better off using solder wick/braid. You'll get a few metres of the stuff for the same price.
emaxxracer15
RC-Monster Maxx
10.06.2008, 07:27 PM
ok so i just finished my first 6s1p a123 pack for my emaxx build and when i plugged the balance tap in to my hyperion EOS0606i charger i get a bunch of beeps saying the balance voltage is too high, i have no idea how to lower the voltage to an acceptable level. suggestions...
MM rustler
JThiessen
JThiessen's Avatar
10.06.2008, 11:07 PM
Just some semi obvious things you might check:
1) Do you have the latest software? The latest one made the Hyp's a little less restrictive.
2) Triple check the balancer wiring (I'm sure you've done that).
3) Did you make sure you have the voltage set correctly on the charger? Can the charger charge that high? Just a question as I dont know the limits of the particular charger you have.
If nothing else, run the pack down a little and try it then????
