View Poll Results: Which motor (read post first plz)
Neu 1515 2.5d f 1650kv 11 33.33%
Neu 1512 3d s 1700kv 22 66.67%
Multiple Choice Poll. Voters: 33. You may not vote on this poll
jhautz
jhautz's Avatar
07.22.2008, 07:17 PM
I have both the 1515/2.5D/F and the 1512/3D/S Both are great 5s motors for a buggy. It really depends what the primary use will be. If you will be bashing it and driving it around in grass and such go with the 1515. If you are building a dedicated track vehicle go with the 1512. The 1515 is a bit more versitale with the gearing it will allow you to run due to it larger size and more power, but the 1512 is ligheter and more than enough power for any track.
to make it...
or break it...
Silent...But Deadly
rootar
rootar's Avatar
07.22.2008, 09:11 PM
well what diameter are the finned nue motors? i think the smooths are 39mm arent they and the finneds are 42mm. i know i could easily fit a 12 tooth or less with the XL and mikes heatsink and prolly the smooth can but i dunno about the finned, mike only has a 1512 2000kv finned neu while impackt has the 1512 1700 kv smooth can.
will the smooth can be good enough and where can i find a heatsink for it?
jhautz
jhautz's Avatar
07.22.2008, 09:57 PM
you dont really need the fins with a Neu. I run the smooth 1512/3D with no heatsink or anything and I get temps around 160 or so after a 20 minute main. The neus run cool enough. The fined probably do run cooler, but how much...
to make it...
or break it...
Silent...But Deadly
rootar
rootar's Avatar
07.22.2008, 11:21 PM
your right the whole motor mount and chassis act as a big heatsink reguardless.
bdebde
That's All Folks!
bdebde's Avatar
07.23.2008, 12:43 AM
Finned can is 44mm. If 12t is smallest pinion that will fit with an XL (36mm), then a 15t would be the smallest you could go with a smooth Neu (39mm). And 20t with the finned (44mm).
.... The fined probably do run cooler, but how much...
About 20 F according to Steve Neu.
rootar
rootar's Avatar
07.23.2008, 12:59 AM
no no no i could run a 12 tooth forsure with a smooth neu with a finned i would fit my rear brace with a 14 or 15 i believe, but all i can find instock is the smooth can so i guess i need to find a 39mm heatsink for it.
azjc
07.23.2008, 02:50 AM
I wouldnt worry about a heat sink for a Neu...I have never heard of a Neu frying due to the temps being too hot
Mozzy
Mozzy's Avatar
07.23.2008, 07:24 AM
Would these be suitable for a buggy/truggy?
http://www.hobbycity.com/hobbycity/s...idProduct=6526
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
azjc
07.23.2008, 12:07 PM
you get what you pay for.......dont expect that motor to last very long
bl-is-future
bl-is-future's Avatar
07.23.2008, 12:08 PM
^^^+1
Matthew_Armeni
Matthew_Armeni's Avatar
07.23.2008, 05:10 PM
1509 2Y 1820kv
Lightweight, powerful, fast, great track motor, draws 55 amps.
1512 3D 1700kv
Same as above but it draws 70 amps, and it will have more torque.
  Send a message via AIM to Matthew_Armeni
rootar
rootar's Avatar
07.23.2008, 05:11 PM
i think a found my motor!!! NeuMotor 1512/3D/F/H it the heli version, has an internal fan, aluminum rear cap for the fan, and the body is also finned! all that and its on clearance from a heli store, it is awefully big but hey i can put 3mm spacers under the center diff and it has enough clearance everywhere else that i could go down to a 14 tooth pinion. (smallest i need to go is a 15 tooth)
what do yall think its 44mm around the finned area, in the rear it has a 50mm diameter ring as part of the cover over the rear fan, and its 71mm long, and it DEFINETLY will fit with 3mm spacers under the center diff OR if i grind the 50mm ring flat where it would touch the chassis
what do you guys think? should i order it or not?
ID:	5083   Click image for larger version
TDC57
TDC57's Avatar
07.23.2008, 10:22 PM
That quite a motor Ross, I was going to recommend the 1512 2.5 Ds or the 1512 2 Ds, the 3d should run real cool on 5s... I would be a little concerned about raising the center mount 3+mm (more than the 2mm existing) there is a tremendous amount of torque there so the shims used would need to span a large area to ensure that the force is equally distributed, something to thing about.. Maybe..
How much for that bad boy (?)..
Have a great one..
Nothing!.. Hahahahaaa..
rootar
rootar's Avatar
07.24.2008, 09:24 PM
Product ID: RCMNEUcover
Product Name: Neu Rear endbell cover
Quantity: 1
Unit Price: $7.50
Product ID: RCMfrontmotorcover
Product Name: Front Motor Cover -Lehner/Neu
Quantity: 1
Unit Price: $12.00
> Motor Front Cover : 4mm front cover
Product ID: NEU_1515_2.5dF
Product Name: Neu 1515 2.5d/F Sensorless Brushless Motors
Quantity: 1
Unit Price: $255.00
Product ID: rcmst10mount
Product Name: Electric Motor Mount HB Stadium 10
Quantity: 1
Unit Price: $45.00
Product ID: rcmstickers
Product Name: RC-Monster Sticker Sheet
Quantity: 1
Unit Price: $2.00
> Sticker sheet : 6"X6" sheet (+$1.00)
Order Total : $322.50
Shipping : $12.04
Grand Total : $334.54
i figured itd be a better purchse to go ahead and get the 1515 so later on if i wanted to i could put it in a truggy or mt on 5-6s, plus it was the only motor out of my choices that Mike had instock........
