azjc
08.05.2008, 02:34 PM
Originally Posted by 1maxdude View Post
I ran my cc bec wire along side my power wires on the mm. Then soldered both the mm power wires and cc bec wires to the battery plug together. It's a bit hard to get the shrink tubing to fit over everything, but it does with a little work. I then ziptied the cc bec and mm power wires together so they don't try to come seperated and yank out at the end. Also, there are places that sell pre made dean's Y adapters to wire in 2 batteries in either series or parallel, whichever you prefer. That is if you are using dean's plugs, not sure since you mentioned bullets. Or you could look at one and make your own harness. And as already mentioned, make sure you pull the little red wire comin off your mm that goes to the rx out of the wire harness and you should be set.
here is the Deans series adapter I use
http://www3.towerhobbies.com/cgi-bin...&I=LXNKY9&P=ML
Ev1er
08.05.2008, 05:25 PM
Do I have to use the bullets?
Can't I just solder the wires right on the battery?
I will show in a paint picture.
And one more thing...
Nobody has replied to me if the Mamba Max ESC has an internal BEC!?
Can someone say if the wiring diagram I draw on the picture is correct??
Please help me!
I really appreciate that you guys can hel me with this!
Thank you!
-Ev1er
Name:	Wiring diagram!!.jpg
tc3_racer_001
tc3_racer_001's Avatar
08.05.2008, 05:49 PM
perfect. thats how you do it. :)
u can use either deans or bullets, both are good.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Ev1er
08.05.2008, 06:02 PM
ok, thanks!
but DANG!!
Can't anyone answear me if the MM ESC has an internal Bec or low voltage cut-off???????
azjc
You have to use a connector of some type you need to be able to remove the battery so you can charge the pack and so the pack doest drain and puff on you
08.05.2008, 06:06 PM
The MM has a built in BEC, but it should be disabled to use an external BEC (remove redwire from the rx lead plug, and cover with tape or shrink tube).
Ev1er
08.05.2008, 06:10 PM
Where do I have to use a connector of some type?
Show me on my drawing!
RBMike
RBMike's Avatar
08.05.2008, 06:27 PM
You don't have to have a connector on it. Just solder it the way your drawing is drawn & you'll be fine.
