Snipin_Willy
Snipin_Willy's Avatar
09.12.2008, 01:58 PM
Well even with the lack of input I've decided to step up to the plate and go with the Neu 1509 1.5y. I hope it gets here soon!
Now to get a dewalt 36v battery and tear it down and rebuild it into some useable packs. I plan on attaching balancing leads to the cells, is there a particular balance that works with A123 cells through a charging port on a battery charger (IE inline balancer, [charger]->[balancer]->[battery])?
jnev
jnev's Avatar
09.13.2008, 02:55 AM
I got a chance to install the motor and get all the connections on the truck done. However, it was dark, so I only got some limited testing done in the garage. Looks to be very powerful, and start ups were as smooth a brushed set up. One problem: I just found out (after testing in the garage) that the front drive shaft is bent. I think it happened with my old motor while running it a while back. So I guess I won't be able to test it this weekend after all, as I ordered a drive shaft tonight and am expecting it next Monday. I think you'll be very happy with the motor though.
Snipin_Willy
09.14.2008, 11:07 AM
Okay, I need to replace the turn buckle end balls, does anyone have a link to the replacement part, or a better/upgrade for them? I attempted to use some end balls from my 1/10 nitro truck that never gets used any more but they are too big. A tower hobbies link would be great because I have to order some other stuff through them anyways.
Edit: also, an aluminum servo arm would also be nice.
Snipin_Willy
09.14.2008, 09:50 PM
jnev, what battery are you using to run that 1509 1.5y? I'm looking at the dimensions of a 4s A123 pack and it seems it might be a bit large.
BlackedOutREVO
09.14.2008, 10:50 PM
He has a flight power 4350 evo lite pack, 18C
Fitting A123 cells in a .5 would for sure be hard to do, but you could probably stand them up, and they would fit fine. But would be heavy...
jnev
jnev's Avatar
09.15.2008, 01:07 AM
Its actually the 4370mah pack, but close enough.
BOR - when are you gong to show us your sweet new build!?
BlackedOutREVO
09.15.2008, 10:04 AM
I have changed it around so much. Pm me if you want to know lol, but its going to be extremely different then all the other crt.5's! And no, its not the out runner .5, im going to have my buddy do that to his, its cheaper for him
Snipin_Willy
09.15.2008, 11:23 PM
After some careful thought and consideration, I've decided to stay the coarse and go for A123 cell project. Initial cost will be more, but additional packs and life time of the packs might make it worth it. Plus, don't have to worry about discharging too far, over charging, fire, puffing.
4370 is a big pack! Is that a 3s or 4s?
BlackedOutREVO
09.16.2008, 12:03 AM
Its a evo lite, 18C, so its super light! Im sure he gets some crazy runtime! It is 4s
Sounds good! Make sure you get some pics going!
Semi Pro
Semi Pro's Avatar
09.16.2008, 09:02 PM
man i want one of these, will my 1512 fit of is it way to big for the .5?
jnev
jnev's Avatar
09.16.2008, 10:58 PM
A 1509 size motor is plenty for a CRT.5. A 1512 would be more suited for 1/8 buggy. As BOR said, the pack is 4s and is very light. And yes run times are awesome. It is probably a little more now, but when I weighed it with the Lehner motor in it, it was sub 5 pounds.
Semi Pro
Semi Pro's Avatar
09.17.2008, 11:31 AM
thats cool, i figured it would be alittle to much, im looking at a 1509 and i am really trying to decide how big of a pack i need
maybe someone can help
i rember someone was running a 5 cell 2500mah pack and had about 15min of run time, thats all i really need is 15min
can some one post a link?
MetalMan
MetalMan's Avatar
09.17.2008, 11:42 AM
Some guys have enough had good luck with the 1509 in 1/8 buggies .
Snipin_Willy
09.17.2008, 02:01 PM
Does anyone know what happened to the rear endbell covers for the Neu 1500's? I can't seem to find them.
09.17.2008, 02:05 PM
I think mike removed them as he's working on a new design - They became impossible to make with the new nue endbell arrangement
