mxracer
08.18.2008, 02:39 AM
sylv motor is a 1515 2.5d (1700kv, we are talking about 1512 2.5d (2050kv)
keep with what you got atm i reckon .. see if you can make the 30 mins . if not you might have to look for just a bit bigger battery ( 6000mah - 8000mah )
for my long runtime setup im planning on buying a flightpower 10s 3700mah pack , and split it so its 5s2p which = 7400mah , they are not much bigger or heavier than a flightpower 5s 5000mah pack
losi 8ight-t 1515 tekno 1Y/MM 4s/5S flightpower
losi 8ight-t 1515 tekno 1y/MM 4s/5S flight power
RIP 4x MMM . MM still lives on !
mxracer
08.18.2008, 09:05 AM
well i did 2 packs with the 1512 2.5d (2050kv)
hyper 8
4s flight power 4900mah
geared 13/46
MM with fan , lvc 15v , 5deg , low start power , 50% punch control
1st pack , i picked up , wasnt fully charged , so it was a gear warm up
the second pack just bashing in the park , turns and top speed runs.
14 mins
motor and esc both 70deg C
sorry to offend but anyone that gets 35-40 mins runtime from the same setup is either talk (*&^&^ or they must never touch the throttle over 50% ( eg very skatey slippery track)
Sylvester
Sylvester's Avatar
08.18.2008, 11:13 AM
Ill time my car today with track use and get back to you with the time.
Im sure if there was a 6000mah flightpower pack you could do 30 minutes with your 1512 2.5d. I accidently got the 1515 instead of the 1512 but im not complaining since i got it a 1515 at the cost of a 1512 :)
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
mxracer
08.18.2008, 11:17 AM
that be sweet , get a time .. oh thats right you the lucky one to get it from the parts bin at neu !! bargain !!
hey can u find a grass park or something and just do , a fast bash session there and see what sorta run times you get driving hard on grass (short cut) .
im thinking the traction is what might drain alot of runtime
Sylvester
Sylvester's Avatar
08.18.2008, 04:44 PM
Okay so im back from the time test.
mixed grass running with some tracktime.
Duration: 30:51 before the lvc kicked in!
I used a stopwatch and i never stopped to check temps so it wasnt babied.
Its a very accurate reading so i can cheerfully say i get 30+ min runtimes with a single 4s 5000 :)
Losi 8ight e
tc3_racer_001
tc3_racer_001's Avatar
08.18.2008, 06:10 PM
now lets see a 30 minute video :P nice job!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
kevin23
08.18.2008, 06:58 PM
WOW!,I ordered the 50t spur,and I ordered the tekno long shank pinions for tekno today.
I ordered a 12 and a 13t,I will try the 12 to see if the batt temps come down and the runtime should go up,I hope so anyway.
Is there any drawback to running the pinions and using the mechanical brakes still.
I'm going to keep the mechanical brakes to try and save the mah as much as possible.
I know it is not much,but every little bit helps.Would running the pinions help put some"charge" back in the batt's when off power since the motor still turns or does it not work like a brushed motor in that aspect?
Thanks again guys,
Kevin
kevin23
08.18.2008, 07:07 PM
Here is a link to the race results from this weekend.
Both classes were 15min mains,I was running the e-revo and the e-8
http://www.triplenickelrc.com/raceresults81708.htm
I was running the buggy pretty hard,I was only hit full throttle on the straightaway though,it is too fast on the infield
kevin23
08.31.2008, 09:35 PM
I run the buggy again today with gearing 13/50 and the motor heated up to 170 after the 15 min main.
I also lost some runtime,the batt took 4000 mah when it normally takes between 2500-3000 mah after the 15 min mains we run at our club races.
would being undergeared cause the extra capacity to be used?I pretty sure the motor temps were up because of the undergearing
Sylvester
Sylvester's Avatar
09.01.2008, 11:19 AM
Defiantly a factor which could have reduced runtimes, id try 15/50 and try again.
Losi 8ight e
kevin23
09.01.2008, 04:52 PM
thanks will try
Mike.L
Mike.L's Avatar
09.02.2008, 04:03 PM
now your talking! its a backyard track under cunstruction but its ready to rip. Me and syl completly revamped the area and made it a paridise to escape to
hopefully if weather is good ill video tape him set some bash laps!!
  Send a message via MSN to Mike.L
