08.22.2008, 12:49 PM
Contact B16's - his is looking great - Just need someone with capliers to take final measurements...
e-mikey
08.22.2008, 12:52 PM
I have calipers :)
brushlessboy16
brushlessboy16's Avatar
08.22.2008, 01:33 PM
could i get measurements of the center-to-center distance of the center diff mount holes (where it attaches to the chassis)
also the distancece between the inside of the front and rear center diff mounts
e-mikey
08.22.2008, 02:23 PM
I'll get that for you tonight with pictures so you can see if it's correct.
e-mikey
08.24.2008, 12:42 PM
Okay, this is my first time using calipers, not sure if it's right...
for the mount holes I have 34.70 front to back, 21.15 side to side, 40.74 criss cross.
tom255
tom255's Avatar
08.22.2008, 01:52 PM
Here some pics of mine motor mount
08.22.2008, 01:59 PM
How does the top plate attach to the motor mount? - Any clearance issues with the rear brace?
e-mikey
08.22.2008, 02:27 PM
looks like it's all one piece.
08.22.2008, 03:08 PM
Can't be otherwise you would have to machine LOTS and LOTS of metal away to get that shape!
e-mikey
08.22.2008, 03:34 PM
I see what you are saying..
tom255
tom255's Avatar
08.22.2008, 04:49 PM
Top plate like a brace what is fixed behind with screw on motor side. I will redesign for simplier faster fix. With 12t pinion and hyper 8 default spur Medusa 60mm motor allmost tuch rear torque bar. Maximum gears are 18/52. XL motors (74mm) will not fit with low gears.
Hyper 8 have stupid diff mount what makes diff/motormount difficult to mill. I have only 3 axis machine so i need to do additional details (shims) or trimm it by hand to fit it.
tc3_racer_001
tc3_racer_001's Avatar
08.22.2008, 06:40 PM
silly question. but would there be any way to mount it the other way? like to get it out of the way of the rear chassis brace? looks good though! keep up the thinking guys!
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
brushlessboy16
08.22.2008, 06:50 PM
hmm elaborate on that, i dont follow?
tc3_racer_001
08.22.2008, 06:59 PM
dont worry. im an idiot lol.
i thought if there was any way to mount the motor the other end of the diff, but to do that u would have to have a HUGE shaft... OR have a really HUGE pinion to clear the top of the diffmount. (i.e. a spur sized one! haha.)
edit: OR flip the diff round, then it would work maybe? u would ahve to cut out a slot in teh bottom though, not too difficult if you really wanted a longer motor...
hyper 8.5 pro SOLD!
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
tom255
tom255's Avatar
08.23.2008, 03:13 AM
On buggy if you flip center diff it will not fit under body. Two - three solutions to fit bigger motor, redesign rear torque bar or use bigger spur gear, place some spacers under diff or make new whole diff mount what is taller.
I designed mount for 60mm medusa motor its more than enough on buggy, no reason to use any bigger motor on that.
I will put 74mm motor to get gearing limits...
