ogrfre01
08.25.2008, 04:20 AM
I acctually think we have the exact same setup.... MMM, 4S Polyquest, and the same motor...... the chassies is the only thing that is different and not the exact same gearing i have 14/48...... im hoping that there is a bad solder or something like that...
ogrfre01
08.26.2008, 12:55 AM
i think i found atleast one problem..... the front bearing on the motor shaft was not ok:
I put a new bearing on there so now there will be some new testing soon.....
Shark413
Shark413's Avatar
09.11.2008, 02:23 PM
ogrfre01, could you explain how you got the rear endbell off? I understand you remove the screws and tap on the front shaft to knock the rear endbell loose. Also, is the rear bearing flanged?
Thanks
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
