hunter306
hunter306's Avatar
09.15.2008, 10:16 AM
Can anyone make a suggestion for a LVC that supports 5s?
I've looked around, but haven't turned up an external module. If anyone can point me in the direction, that would be appreciated.
jhautz
jhautz's Avatar
09.15.2008, 10:26 AM
Mike had a car LVC in his store. Not sure if he still does or not. You have to pay attention to how the LVC works. If it is a plane LVC, when it kicks in it may just throw you into full reverse.... which would be a bad thing. You need to find one that will put the car controller to neutral position.
If that is the 70A BK controller you might want to think about adding a fan on the heatsink. Its on the small side for 1/8 applications.
to make it...
or break it...
Silent...But Deadly
hunter306
hunter306's Avatar
09.15.2008, 10:36 AM
J, I checked out the RC-M store this morning but didn't see anything stand out as an option... I'm toying with the idea of replacing the controller with one that has a built in LVC -- Since like you said -- 70 amp is a little on the low side for 1/8th truggy.
With the 9XL I think the maximum current rating is only 74amp continuous... so far with my 12cell NiMh test, I didn't have any issues with the combination, and the less-tall gearing.
With the 5s lipo, I think Its going to heat up a little bit more... Might have to drop by the rat-shack tonite and get a little DC fan to put on there.
hunter306
hunter306's Avatar
09.17.2008, 07:36 PM
Just a quick picture all trimmed up. Still have to form the lipo battery tray, that's on the schedule for this evening!
hunter306
hunter306's Avatar
09.18.2008, 05:37 PM
Finished up the Battery Tray yesterday night... Hopefully I can get it mounted in the ST this evening and maiden the whole setup!
Here's the battery tray.
bdebde
That's All Folks!
bdebde's Avatar
09.18.2008, 08:34 PM
Nice battery tray, what is it made of?
hunter306
hunter306's Avatar
09.18.2008, 08:36 PM
Hey Bdebde,
I used aluminum to make the tray, cut it here in the shop then bent it to size. Still need to get it mounted though, maybe tomorrow.
brushlessboy16
brushlessboy16's Avatar
09.18.2008, 08:43 PM
what coating is that
hunter306
hunter306's Avatar
09.18.2008, 08:46 PM
BB,
Coated with two coats of Rustoleum Heavy-Duty Primer, and 2 finish Coats of Rustoleum Flat Black High-Temp Coating.
brushlessboy16
09.18.2008, 09:07 PM
very nice :D
Semi Pro
Semi Pro's Avatar
09.19.2008, 08:26 PM
great job on the battery tray
i have been looking for a 5cell lvc for awile too, i havent been able to find anything over 4 cell
hunter306
hunter306's Avatar
09.20.2008, 11:58 AM
Hey SemiPro, thanks for the compliment. The tray came out much nicer than my first attempt (back when I finished an LST2 conversion!)
Here is the setup now, with everything installed and running. I will eventually add a BEC, but for now, the RX pack works excellent, and I can run my BK Warrior setup without the bec enabled.
brushlessboy16
09.21.2008, 09:49 PM
how much for one of those trays?
hunter306
hunter306's Avatar
09.21.2008, 11:55 PM
PM Sent, It's hand-made but I tried to give you a reasonable figure to work with.
CRTIM
09.22.2008, 12:14 AM
very impressive build....can i ask where you bought your battery ?thanks...awesome job
