09.03.2008, 12:31 AM
Like GD, I haven't had problems with the plastic spurs either. It's all about a consistent and proper mesh. They are quieter, cheaper, and lighter as well.
Also, back in the day, your typical pinion would be eaten up in short order with a metal spur and there was a shortage of reliable hardened steel pinions, so most everyone used the Kyosho spur with regular pinions.
During the "Kyosho spur" days, I started a discussion on this topic. Since then, things have changed: http://rc-monster.com/forum/showthread.php?t=4383
MetalMan
MetalMan's Avatar
09.03.2008, 01:02 AM
Originally Posted by glassdoctor View Post
I've never had a problem with the plastic gears either. Only if the motor slipped and mesh got real loose... then you will strip a gear. But even then, it's only $5.00
Running metal gears isn't so bad now that we have good pinions for $10-15
Not long ago, it's was very costly to run metal-metal. I've run plastic for several years now.... racing and bashing... works for me and it's quiet.
My problem was the motor loosening up, on my Hyper 8 at least. In my Savage, with perfect mesh, I was MELTING Kyosho spurs. Like stripping, but there was never any stripping.
And for now at least, Mike is out of Kyosho spurs.
coolrunnings
09.03.2008, 03:41 AM
Steal spurs are the ultimate reliable bash set up. Only way to go.
ffactory666
09.03.2008, 04:09 AM
Took a while to get use to the noise but metal to metal for me all the way baby
totallylosi
02.24.2011, 09:09 PM
Originally Posted by cornolio View Post
i think it depends on the car.ive never damaged my plastic spur on my xt8 inspite of very hard crashes(even bended cvd's)
but i used up 4 plastic spurs on my cen arena so i got rrp spurs for it
I want to use a plastic spur gear on my XT8. What spur gear did you use? Do you have a link or part number for me so that I can order some. Thank you for your time and concern
totallylosi
02.24.2011, 09:10 PM
aqwut
Brushless Heavy Weight....
aqwut's Avatar
02.25.2011, 12:25 AM
I use Kyosho nylon spur and HPI Savage Spur gears on my 18Lbs GST, and haven't had any problems.. Mind you that I use mechanical brakes... I had chipped pieces of metal stock on the bearings/shaft/can of my brushless motors. Some how, those small shavings always seem to find a way to get inside the motors. Just a thought.
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
