its me
There is no help for me... I'm addicted to R/C
its me's Avatar
09.15.2008, 03:57 AM
off the box and on its own feet..
rccna.com
Semi Pro
Semi Pro's Avatar
09.17.2008, 11:10 AM
wow
im really impressed with how this is turning out
MetalMan
MetalMan's Avatar
09.17.2008, 11:50 AM
It is coming together very nicely. I am interested in hearing how your 4 link setup works to compare it to mine, since my links will be about 2in. longer than yours.
its me
its me's Avatar
09.17.2008, 10:41 PM
Will do man, I am hoping this Frankenstein will be able to be raced LOL. I need to make some limiting straps, trim the chassis and figure out the lay out of everything. I also raised the front end assembly so I can get more down travel to compensate for the 4 links suspension travel.
rccna.com
its me
its me's Avatar
09.17.2008, 10:42 PM
wow
Thanks man!
rccna.com
its me
its me's Avatar
09.19.2008, 04:20 AM
Some parts came in and got more done today..
redid this..
Motor is only for mock up.
What do you guys think? should I run twin lipo's and get creative with the mounting of electronics? Or should I just run one lipo?
rccna.com
brushlessboy16
brushlessboy16's Avatar
09.19.2008, 07:32 AM
wow thats truly a work of art..
with a longer can motor will the can hit the upper links on the rear suspension?
MetalMan
MetalMan's Avatar
09.19.2008, 01:01 PM
The RCM CRT.5 motor mount threw me off for a minute, it just looks so good in there! Not to mention the carbon fiber really gives the truck its own personality.
If I may ask, what did you use to shape the carbon fiber?
its me
its me's Avatar
09.20.2008, 12:33 AM
Sure man, I cut a piece of 3003 aluminum into a the shape I needed and drilled it for everything. Then all I did was cut the carbon out and sanded it to shape using the template of aluminum.
rccna.com
its me
its me's Avatar
09.20.2008, 12:35 AM
Probably but im also planning to limit the suspension, I already have to much articulation.
rccna.com
Options...
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Options... - 09.20.2008, 04:16 AM
That motor and center diff setup is quite creative. Nice work. Just shows you how easily things can be done when you put your mind to work. I would surely setup for two Lipos just for the sake of veritility. That way you can run either way. Keep up the good work itsme. I hope to start doing stuff like that once I get all of my Maxx rigs up and runing. That should keep the boys busy while I do other things.
its me
its me's Avatar
09.21.2008, 04:21 AM
Thanks man an im alomst certainly going two lipo's, im a sucker for symmetry :)
rccna.com
its me
its me's Avatar
09.25.2008, 04:29 AM
little more work done on this, I should of thought of this before I cut the back LOL
rccna.com
BL_maxx
09.25.2008, 02:54 PM
wow this is cool man!!! i cant wait to see the finished product! how much you got into it?
09.25.2008, 04:23 PM
Stunning!
