Go Back   RC-Monster Forums > Support Forums > Novak
NovakTwo
Senior Strategist
09.08.2008, 12:25 PM
The answer to the wattage question is that wattage is the same no matter the number of cells.
Novak Electronics, Inc.
09.08.2008, 01:04 PM
To clarify, the wattage ratings that the motor can use/dissipate is the same no matter the number of cells.
When you increase voltage from say, 2s to 3s lipo, current will go up (assuming the same gearing), which will cause wattage to go up as well. If this wattage is higher than the motor can handle, then it will overheat. If you increase the cell count, and reduce the gearing, current can drop to approximately maintain the target wattage.
However, our setups are "peaky" by nature, so you'll have high power bursts, and much lower power for normal running. If you pull 1500w 1 second bursts every 5 seconds (20% of the time), then pull 250w for normal running (the remaining 80% of the time), your average power consumption is 500w.
NovakTwo
Senior Strategist
09.08.2008, 01:19 PM
Good question and input. I'll forward this to the ED (Engineering Dept) and see what they have to say.
09.08.2008, 03:33 PM
Hey, did you receive my PM?
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.08.2008, 03:47 PM
Yeah that wouldn't make sense that the wattage is the same no matter the number of cells, because for instance, we all know that a 2000 kv motor on 6s is at least as powerful and efficient as a 3000 kv motor of the same design on 4s.
Area 52 Ranch Raceway
T.R.C.R.
NovakTwo
Senior Strategist
09.08.2008, 05:12 PM
Yes, been busy today---I'll try to get an answer tomorrow.
crazyjr
crazyjr's Avatar
09.10.2008, 09:11 AM
I will say first that i have no problems with novak's, they are good starter systems, with potential for racing, perhaps a bit better than most high-end brushless setups. I love how Novak seems to have matched Nitro's power to weight ratio, Most high-end unsensored setups may be overpowered. That said, the origional poster may want to get a stronger setup. a 14 pound muggy may be a bit too much for the little (380 diameter rotor) Novak hv to handle. Sorry Novak two, but i think the HV, even the 7.5 or 8.5 (whichever is the highest wind) would be in a bad situation
SpEEdyBL
SpEEdyBL's Avatar
09.10.2008, 02:57 PM
Well if you're really in love with novak then you could get two hv systems to put in your truck. :)
T.R.C.R.
NovakTwo
Senior Strategist
09.10.2008, 04:20 PM
I'm thinkin' no one loves us that much......
NovakTwo
Senior Strategist
09.10.2008, 04:28 PM
Originally Posted by jayjay283 View Post
I have a 15lb Muggy with big Joe tires and I want to run Novak because im loyal, What do you recommend as gearing for a 14lb monster truck with 8" 1lb each wheels ? (x4) its all roar right
I asked Bob and he said it's probably like putting a Volkswagon motor in a Hummer. If you gear it correctly, it will move ---but very slowly.
He said 2 HV Pro Systems would do the job.
crazyjr
crazyjr's Avatar
09.10.2008, 06:40 PM
I really think the main complaints are: That you guys were a bit behind on Lipo cut-off, and the small diameter rotors in the MT motors. I started my brushless adventures with an HV system and will never trade them memories for anything, But i wanted more power and a Lipo cut-off, So i went mamba and eventually to quarks for my MT and HV needs. I still love novak's and will consider one for racing, now that the Lipo cut-off is in the esc. I'm hoping to run a G2R revo or E-revo next year in Nitro classes
phatmonk
RC carbon junkie
phatmonk's Avatar
09.11.2008, 10:10 PM
Will the Novak pro HV 6.5 System work in a E Slayer
TexasSP
Something, anything, nothing
TexasSP's Avatar
09.12.2008, 09:50 AM
No reason it shouldn't. Being as light as the slayer is, you could gear up more than on a revo or maxx.
www.cubicle101.com
SpEEdyBL
SpEEdyBL's Avatar
09.12.2008, 11:19 PM
Novak claims 40 mph even with their 8.5 turn non hv motor.
T.R.C.R.
tt-01 mamba
10.28.2008, 09:57 AM
Originally Posted by crazyjr View Post
, So i went mamba
Shhh,
You can't say the M word in novak's territory.
