auto2
09.09.2008, 10:41 AM
if you disconnect one motor wire you will get exactlly the same thing soooooo... hope for a bad joint
MetalMan
MetalMan's Avatar
09.09.2008, 11:43 AM
Exactly my thoughts. If it's not a poor solder connection and all the MMM's FETs are intact, then next item to question would be the motor
Lee Estingoy
Castle's Odd Jobs Guy
Lee Estingoy's Avatar
09.09.2008, 11:50 AM
Just an idea here. Any of you guys with the stuttering/cogging controllers have a second motor you could connect to the controller to make sure that it really is the ESC that is having problems?
Doesn't have to be a motor capable of driving your car, just any brushless motor...
I just had a situation with a setup where one of the motor wires had come loose inside the motor can. Everything looked great, motor just waggled when power was applied. Tested OK when we pulled it out of the vehicle, but a little tug here and there and the wire came loose.
If a setup doesn't work multiple times, I mean with multiple Monster controllers, start looking for another point of failure. We really do test these things before they leave the shop.
Lee
phatmonk
RC carbon junkie
phatmonk's Avatar
09.09.2008, 05:26 PM
Wow this is awesome Castle Creations is adding new members to the forum who are Tech gurus! Thats freakin sweet!!!!!!!!!!!!!!!!!!!!!Thanks
09.09.2008, 05:28 PM
lol, pretty soon, we're gonna have their whole staff here!
83gt
09.09.2008, 05:31 PM
What motor is it ? Check that motor screws aren't shorting against the windings. That can produce exactly the symptom you describe, and can make short work of the ESC.
09.09.2008, 07:43 PM
The more knowledge the better!
JaySki
JaySki's Avatar
09.09.2008, 08:15 PM
OK.. So I tore down all my solder joints... I think I have more burns and blisters on my fingers now than I did in 8 years working on Navy Electronics. :)
It fixed the issue. I think it was the solder joints of the Bullet connectors and the massive wires out of the NEU.
I did try the previous failed MMM and it is still not responding.
I think the issue is that lead free solder that just needs so much heat to flow.
Thanks to all of you guys that chimed in.
George16
Supermaxx
George16's Avatar
09.09.2008, 08:47 PM
Then work will be limited since most of them will be in the forum .
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Countryhick
09.09.2008, 08:50 PM
Did you re-solder the castle pre-assembled bullets also?
I read in another thread a guy who had a cold solder joint on one of the castle fitted 6.5mm male bullets.
Just wondering if faulty solder joints are to blame for some of the MMM failures?
Cold solder joint on the motor side causing the speed control to over heat and letting the smoke out??
Cold solder joint on battery side causing some BEC issues???
I know it wouldn't explain all failures but could it be contributing???
JaySki
JaySki's Avatar
09.09.2008, 09:11 PM
I used new wires from Castle from one of my new MMMs. So they did get changed out, just not re soldered by me.
phatmonk
RC carbon junkie
phatmonk's Avatar
09.09.2008, 09:26 PM
Iam glad you found the problem.I guess this is a good example to point out problems that a regular guy can fix.As for burnt fingers I work as a Chef and basicly have tempered fingertips.Why lead free solder?
JaySki
JaySki's Avatar
09.09.2008, 10:05 PM
That's what they tinned the NEU wire ends with. Wires are short enough that I didn;t want to cut them. Seems most are using lead free now. It's a good thing, but add the extra heat for teh lead free solder on top of the massive wires for the NEU AND the 6.5 bullets... I can see how it happened.
MetalMan
MetalMan's Avatar
09.10.2008, 02:29 PM
It's a requirement for electronics sold in Europe, and it's just plain good practice for companies.
That said, I use Radio Shack 60/40 leaded solder . But I make sure to wash my hands before eating after handling that stuff...
Larks
09.13.2008, 10:25 PM
That eyeball on your avatar kinda makes me sick to my stomach! Kinda trippy.
Glad you found the problem. 9 out of 10 its mechanical. .9 of the rest is somewhere in power, and only the .1 last is something really wrong with a component.
