MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
09.24.2008, 09:22 PM
Originally Posted by saydee1800 View Post
well 5s is in I have it geared at 48/15 can I do better with gearing I was hoping to put a 20t pinion
maybe 52t spur?
or just run 48/20?
5s on 10xl should be great. Gear as low as possible (with in reason of course) at first. Then gear up if everything says nice and cool. I found mine heated up driving off road but was fine on road. Moved the shift point to later and it seems to be fine now off road as well.
Semi Pro
Semi Pro's Avatar
09.24.2008, 09:06 PM
sweet, its looks like alot of fun
saydee1800
09.29.2008, 04:17 PM
well I now can't get this truck to shift to second
saydee1800
09.29.2008, 06:43 PM
I got it shifting no worries
saydee1800
10.01.2008, 10:22 AM
Trucks been running great
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
E-Revo 4s 8000Novak HV 6.5
E-Maxx 4s 6000Novak HV 6.5
Speed-T 3s 5000
For Bashers, By Bashers - http://www.BigSquidRC.com
cembom
10.01.2008, 04:55 PM
Good too hear it, I think I am going to pick up a savage roller. Yours looks really nice. Flm's chassis is really clean.
saydee1800
10.02.2008, 03:22 PM
I have a new problem I have Pro-Line 40 Beadlock with Pro-Line tire when I get up in speed they become very woblely
does any on no how to fix this
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
Speed-T 3s 5000
10.03.2008, 09:13 AM
Sounds like they are unbalanced. You basically need to add weights or dremel material from the inside of the tires until they spin without wobble; good luck with that is all I can say. My jumbo maxx rubbers are very unbalanced and come unglued from the rims almost every run- just gotta keep gluing them back on....
saydee1800
10.08.2008, 09:41 PM
I cant seam to get this truck to steer strait with out adjusting the steering on my controller. what is the right servo arm I should use? with this Hitec servo
thanks guys
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
Speed-T 3s 5000
VintageMA
VintageMA's Avatar
10.08.2008, 10:27 PM
thanks guys
Am I the only one to notice this, but aren't the wheels mounted facing the wrong direction of rotation?
“Everyone has a right to be stupid; some people just abuse the privilege.”
blueb8llz
10.08.2008, 09:56 PM
and you didnt have this problem with the other tires/wheels? if not, then it is most likely unbalance tires. maybe try fitting your tires again, the foams may have shifted inside. do you have sloppy steering? make sure all screws are tightened down on the steering assembly. servo saver spring weak? put some toe in on the rear tires. you can try putting some spacers on the front springs to make them stiffer than the rears. check your hindge pins and shock bottom caps.
saydee1800
10.10.2008, 07:39 AM
Thanks Vintage! I did have my tire backwards. Well the steering was not a true problem. I brought my savage in to the shop an ask the. they told me that I will never get the servo to go true 0. We did adjust the sub steering trim and now its prefect.
By the way I have gps this FLM @ 48.2mph geared at 20/52 with my 10xl
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
Speed-T 3s 5000
blueb8llz
10.10.2008, 06:01 PM
so now your trucks tracks straight?
saydee1800
10.10.2008, 06:59 PM
yes it is strait I fix in my fasst controller in the sub trim
Maxamps Lipo's
FLM Savage 5s 5000
Mamba Monster V2
Feigao XL 10
Speed-T 3s 5000
big greg
10.10.2008, 07:09 PM
how are your temps on everything?
