Checked the solder connections...all seem fine
I have shrinkwrap around the Bullets on the MMM blocking the heatsink ground issue
failsafe is neutral
and it wont be used to open a beer unless it burns out and takes my servos out like the last one
think it may have been the spektrum...but time will tell
I had same thing happen to me. Nothing to do with the MMM or the radio. When crap goes onto the gears in the tranny the car comes to a grinding halt. It turned out an e-clip in the tranny broke for some strange reason and when it went into the gears the car stopped.
The capacitor only helps if the issue is due to voltage dipping - If it is interference then it won't do anything. Only eliminating the source, rx/antenna placement or upping the gain on the TX would help.
I had glitching from voltage drops (could see the Rx reset), and added a 1000uf low esr cap to no avail. IT was really strange, with the CCBEC hooked up, the lowest voltage drop I would record stabbing the throttle with an unloaded motor was 13.2 down to 8V - still enormous but still higher than what the ccbec was set at.
Removed the ccbec and no more substantial voltage drops or rx cutouts *shrugs*
I had a CCBEC used with my MM. I had all kinds of trouble with my Specktrums glitching & loosing their bind with the TX. I switched to a Novak hvbec & no more trouble.
