Something, anything, nothing
09.26.2008, 06:07 PM
I know about the Dude's mount and it looks nice, just probably will be on the expensive side. I think something more simplistic and less costly is in order. Turning it over to Mike would be good as well, I would just assume buy everything through him if I could.
09.26.2008, 06:16 PM
I think a modified version of his revo mount would do fine. It would have to place the motor higher up to clear the rear tranny mount, and the base would be larger to bolt on using the stock nitro mount holes. The rear support would be farther away from the front plate, but that does not really matter, as no one will be using a L can length motor in an lst (traxxas newbs who want a velineon in an lst are excluded in that last statement...)
09.27.2008, 10:38 AM
Yup, that would be nice.
I was thinking a mount for a 5B as well, but make sure I can run my velineon on it is well, after all, it's a tough little motor.
Seriously though, a 5B mount would probably be a decent seller, and/or an e-maxx/e-revo conversion to 1/5th buggy kit like lydiasdad made.
09.27.2008, 12:14 PM
A quad velineon setup on a 5b would be funny... I can imagine the cool parallel adapter that would take 4 2s packs and distribute them evenly to 4 vxl escs....
09.26.2008, 06:32 PM
make me a motor mount for my cen, which has a 66t spur.
09.26.2008, 06:44 PM
how about a system to charge LIpo batts while truck is driving!...a tiny alternator type thing!!!...endless runtime and no charging!
Soldermaster Extraordinaire
09.26.2008, 06:47 PM
That's called over-unity, my friend. If someone could come up with that it would solve more problems than poor runtime in our RC vehicles!
09.26.2008, 06:48 PM
Hmm, a 200% effecient alternator... Something tells me that I would be rich beyond my wildest dreams if I designed that!
Does the RCM mount for Cen not work?
09.26.2008, 07:03 PM
not enough adjustment, its designed for the buggy, not the truggy..
buggy uses 46t spur
09.26.2008, 08:31 PM
wanna help out? PM me
09.26.2008, 09:30 PM
come up with something to make the stock slash tires softer, the tractionless sob's drive me nuts, and in electric state series your required to run stock tires but nothing says you cant groove them or soak them in something to make them softer.....
09.26.2008, 09:39 PM
soak them in wd 40.
drag racing trick, softens the rubber right up and makes them extra sticky
09.26.2008, 11:33 PM
Or just use end-nipping pliers to cut out half of the tread pattern. I did that with a set of Masher 2Ks... Oh my.  I could have won a full-scale tractor pull with those things!
any chance at that mount? :D
