MetalMan
MetalMan's Avatar
11.16.2005, 12:26 AM
The Thunder Power will be able to charge up to 10amps and 10 cells in series (Lipo). Otherwise, you could charge at a slower rate (and get a less expensive charger). And yes, 2 packs can be charge in parallel. I would recommend you pick up a balancer to occasionally balance the packs to keep them as a longer lasting investment.
squeeforever
squeeforever's Avatar
11.16.2005, 08:44 AM
do you have a link to were i can find the thunder power charger?
MetalMan
MetalMan's Avatar
11.16.2005, 09:49 AM
I am pretty sure it isn't out yet.
squeeforever
11.16.2005, 04:35 PM
is there a charger that can charge 5s lipo at 10 amps and preferable be able to chage nimh to?
mmdooley
mmdooley's Avatar
11.16.2005, 05:07 PM
Hi guys, I am new to the boards and I am building a bl E-MAXX. I see yall are talking about LiPo's. Has anyone looked at maxamps.com? they have up to 8000Mah 11.1 v LIPo's! sounds real good. and they fit in a E-Maxx style tray.
mmdooley
mmdooley's Avatar
11.16.2005, 05:24 PM
Yes squeeforever, The intellipeak ice charger will charge both but It only chargers 1-4 LiPo's at 1C max. for Li-Ion/Li-Po). whatever that means.
WE DON'T STOP PLAYING WHEN WE GET OLD. WE GET OLD WHEN WE STOP PLAYING.
Serum
Serum's Avatar
11.16.2005, 07:11 PM
Hi MM, welcome to this forum! yeah, we know about maxamps for sure!
Nothing fancy about those 8400 packs, it are just 4P 2100's, that's why they deliver the power they can.
You can also make a 16800 mAh from it if you like
@ squee; what 5000 packs did you find? is that 5000 on 1P?
squeeforever
11.16.2005, 07:18 PM
there tanic 5s2p
MetalMan
MetalMan's Avatar
11.16.2005, 07:29 PM
Squee, the Schulze chargers can do that, but I have a feeling that you don't want to dish out $250+. To be able to get the 10amp charge rate you are most likely going to have to spend $200+.
There is this charger:
http://aircraft-world.com/shopexd.asp?id=3001
Can do 5s Lipo at up to 5.7amps (120watt maximum). It can do up to 25 NiMh cells. It is pretty cheap for what it does. I realize that it still does not meet your 10amp desire, though.
Serum
Serum's Avatar
11.16.2005, 07:32 PM
using two chargers isn't that an option? to charge each pack in its own? that way you are able to balance the chargeproces as well. Pity they don't have got balancers that can communicate with eachother..
squeeforever
11.16.2005, 07:33 PM
isnt there a balancer that will work with the astroflight?
MetalMan
MetalMan's Avatar
11.16.2005, 07:34 PM
Yes, using two chargers at the same time is an option. Now, why didn't I think of that? :(
The Thunder Power charger will be able to interface with the Thunder Power balancer, so the balancer can stop or change the charge if it finishes or if something goes wrong.
MetalMan
MetalMan's Avatar
11.16.2005, 07:35 PM
The Astroflight balancer may work with it, but it would make the charge take longer since the Astroflight balancer will attempt to keep the cells at 4.15v.
mack
mack's Avatar
11.17.2005, 09:18 AM
I thinking go extreem put two of this on your truck.
Lipo 10500mA 14.8V 4S
here you got the link it's a French site.
http://www.directmodel.fr/Produits/F.../1/SFamille/51
No not the power is the limet the money is.:L: :L: :L:
Serum
Serum's Avatar
11.17.2005, 03:18 PM
Those cells are not the thing you need.. it takes more than a 4S to run the 8 or 9XL on a savage.. and you don't want one pack hanging on one side on your savage either.
With those cells, the power IS the limit it the setup. it can max. throw out 1500 watts (if you replace the 2.5 mm2 wires) a 18 cell nimh setup can deliver about 1800 watts. you are able to get impressive runtimes with that lipo pack though.
