10.09.2008, 08:09 PM
The 1515 will be a better choice for the Revo...IMO
BTallack
10.09.2008, 08:45 PM
Don't suppose anyone has some temp comparisons between the two?
jacko
Hump-E-Revo
10.14.2008, 02:19 AM
Very nice build on the M-Twin. Looks clean and glad it runs great.
Thanks Neil. I'll keep this in mind. Currently, with my single 700HO, i'm getting the same temp readings below. Good to know. Now the long wait till the 70-2000 Medusa gets delivered.
http://www.scriptasylum.com/rc_speed/_top_speed.html
Aim for 35-40mph at most.
Temps:
motor = 130*F, 180*F maximum
Esc = same pretty much
Batts = 100-110*F average, 130*F maximum (lipos).
Hot motor + cool esc = undergeared
Cool motor + hot esc = overgeared
Hot everything = way overgeared
Warm everything = happy electronics.
E-Revo Basher:
- MM w/ Fan & CC BEC & 700HO (20/68)
- 2 2s2p SPC 8000mAh
- Maximizer 1/2" Offset w/ Badlands
MR4TC CF/Alum Drifter:
- Novak XBR 8.5 Motor & ESC
- 6-Cell 3300 NiMH
- ABS Tires
jhautz
jhautz's Avatar
10.14.2008, 08:54 AM
50mph may be a bit much to shoot for with the 1512, and I prefer a system that doesnt quite run at that rpm, but that said... I run my revo on a 1512/2.5d and 5s and it has no problem geared for 42mph and run on a track. In race conditions it comes off the track after 15 minutes solid run at a cool 140F. I have run a 1515/2.5d in the same setup and it came off around the same temps, but I had it geared a few mph faster. With the setup I have I think there is still some headroom to go up in gearing, I just dont need it for the track, but you should be able to squeeze a bit more from the motor than I am now.
I think you can make that motor work, just start on the conservative side (around 35-40 as others have said) and see how the temps do. if they are fine add a tooth or 2 untill you find the point where you start to run into the motor limit. I dont think you will be too disapointed. Those 1512s can put out some power.
to make it...
or break it...
Silent...But Deadly
BTallack
10.16.2008, 12:51 AM
I got my 1512/1Y today and installed it and that motor is crazy powerful. I geared it 58/20 and got the following temps after 15 minutes of hard bashing and speed runs:
ESC: 95'F
Motor: 135'F
Batteries: 70'F
I'm almost thinking I should kick it up to a 22T pinion if Neil's "Hot motor + cool esc = undergeared" is accurate. (And from what I've seen, Neil is usually very accurate) And it would put me up to about 46mph (adjusted) according to the calculator. Not that I have any objections with the 43mph I'm getting now.
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
10.16.2008, 01:02 AM
It would be cheaper to get a 56 or 54T spur and have a similar effect.
unless of course you already have the pinion.
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
BTallack
10.16.2008, 01:28 AM
Hmmm, you are definitely right about that but I'm not sure the 54T spur would reach the 20T pinion gear. The 56T Spur might work but it wouldn't be much of a difference.
hoovhartid
hoovhartid's Avatar
10.16.2008, 02:02 AM
Is this in a e-revo? or converted?
Because if its in an e-revo, I made a chart that might help;
(short answer is yes, if you mount the motor in the low-cg spot)
This is used in an e-revo with a tekno neu and RCM pinion gears...
unfortunatly, I dont have a 22t, but I got the 20t pinion to mesh with a spur as small as 53T...using the low-cg mounting holes;
BTallack
10.16.2008, 02:23 AM
It's an E-Revo but I'm using the single motor plate and cover so it's not mounted in that bracket. The single motor plate places the motor in the center but higher CoG battery position towards the front of the truck.
I'll post some pictures shortly.
hoovhartid
hoovhartid's Avatar
10.16.2008, 02:35 AM
weird. all the pics I have seen of the single plate, still use the same mount;
BTallack
10.16.2008, 03:20 AM
I just looked it up and holy crap, you're right. My LHS sold me the kit for the E-Maxx.
It does work, but that would work better. Guess I'll have to get the right kit.
I actually feel kinda dumb for not realizing that it wasn't right.
hoovhartid
hoovhartid's Avatar
10.16.2008, 03:28 AM
ah! that makes sense then.
BTallack
10.16.2008, 04:07 AM
Well at least if I ever decide to upgrade my E-Maxx to brushless I don't need to buy a motor plate. ;)
BTallack
10.19.2008, 01:09 PM
Well I got the proper motor plate and installed it. My LHS had to order me the correct cover though.
Unfortunately I foolishly used too much loctite when installed the pinion gear so I can't get the set screw out. I was able to get the Pinion off by heating it up and prying it off so I just need to go get a new pinion gear. I'll be doing that Tuesday so hopefully I'll have my E-Revo up and running then and will report back here.
So far though, no complaints about going with the 1512 over the 1515. It is a Killer motor and very well made. (I was amazed to see that the build date on the motor was less than two weeks before I received it.) No heat issues either.
10.20.2008, 08:59 AM
Blue threadloc (tamiya stuff) is what I use to keep the pinion setscrew in place, rather than normal loctite. With the pinion off the motor now, you may be able to keep screwing the setscrew into it, and that will break the glue seal (if you havent stripped out the hex that is).
