Hello,
can anyone tell me if we can use the motor mount for the Cen Matrix on a Matrix TR Arena mithout mods? If there is something to modify, can you tell me if the holes are the same?
Thanks for your help.
Just out of curiosity, is there a mount that is symetrical top to bottom so it can be flipped upside down? That would give the option of mounting the motor on the left or right of the spur.
The CR Buggy(Jammin') mount has the same hole pattern on top and bottom, but the top uses m3 screws and the bottom uses m4 screws. I don't know if the bearing hole is centered top to bottom, but it is pretty close. Most of the mounts do allow the entire center diff assembly to be reversed by adding a spacer underneath for spur gear clearance(puts motor in left front opposite the steering servo and is common position for dual battery conversions).
The easiest way to determine compatibility is to match the center diff bulk part numbers - if another car uses the same part number and the ST-1, then the ST-1 motor mount would likely fit. :)
