10.24.2008, 06:08 PM
Originally Posted by stum
That's great if you have a rcm tray.. but if you have a tekno v3 tray or any other standard 6cell nimh tray your not in as good of shape... and those sizes are funky since you can only fit max of 150mm ;)
Since most of the larger lipo packs out on the market are longer than a standard 6cell NiMH pack I would consider anything intended to run lipos that wont take a 165mm long pack a funky short tray. Anything shorter and you are limited to the 2s hardcased packs and Maxamps basically.
to make it...
or break it...
Silent...But Deadly
10.25.2008, 02:37 AM
life are great. 15 minute recharge times, 15 mins racing. charge straight after running, then run them again! (work the best at higher temps i found)
i got rid of mine as the just WOULDNT FIT! grr. if they were slightly longer and thinner or shorter and the same thickness they would be ideal but for me in a buggy it was too difficult. lower voltage too.... not that that seemed to matter in my setups.
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
RC-Monster RC8T
10.24.2008, 04:01 PM
Those are all funky long batt's, nothing except the 2s 5k packs fit most battery trays :( Too bad.... those are nice prices.
3s 4900mah fit E-REVO no problem, just remove the spring on top
10.24.2008, 10:28 AM
Some guy told me a few weeks ago about Li-Fe.. He said these cells are like LiPos, but you can charge them really fast, and you can use them 10 times/day..
Did anybody also heard about the Li-Fe cells?
10.24.2008, 04:42 PM
It's LiFePO4, Li-Fe for short. That's the chemistry of A123 cells. Unfortunately you won't find LiFePo4 in a form factor other than a cylinder for the time being.
Brushless Heavy Weight....
10.24.2008, 02:13 PM
Have anyone else tried those Elite 35C Lipos from cheapbatterypacks ?
10.24.2008, 03:26 PM
would this be a good choice for a CRT truggy/ Neu 1515 2.5d/MMM mainly just for racing ,not too much bashing or speed runs
thanks for the help
trying to decide between the Neu,or the Zippy's ,which are cheaper but heavier and bigger then the Neu's ...so i don't mind spending the money if in the long run i will be buying a better quality and performance battery....Thanks guys
| NeuEnergy 5S-1P 5000 Car [4] | $246.00 $184.50 |
* 5000 mAh capacity. Special shape to fit in RC cars.
* 125A continuous, 250A short duration
* Low resistance cells for higher current and less heating
* Balancing taps for safety and convenience (fits Astro Blinky)
* Heavy gauge wire with Deans compatible connector
#Series
| #Parallel
| Volts
| L (mm)
| W (mm)
| H (mm)
| Weight (g)
| | 5 | 1
| 18.5
| 142
| 47
| 35
| 626
10.25.2008, 06:55 PM
I got two of the Neu Energy 5s 4300 packs and they work great. Tons of punch, great build quality, staying in balance. For the money, I couldn't pass them up. Built much better than th.e zippys. Zippys rock though for the money
Certified Spaceball
10.26.2008, 05:01 AM
I've been using the hardcase lipos since they came out and love them. I've got 30+ cycles on 4 of them and they are all going strong. I thought they were a bargain at $95, but $60 is too good to pass up. I also just bought some 3s 3900mah lipos and they work very well. The only down side is that they were a good 10mm longer than advertised on the spec page. So you may want to double check dimensions with a sales assistant before buying a softcase lipo.
rcm xt8
rcm xb8
rcm crt.5
"Out of spec" enthusiast
10.26.2008, 05:24 PM
Yeah my NeuEnergy 4100 mah pack was about 25 mm longer than advertised. Exactly the same weight, thickness and width though.
10.27.2008, 01:49 PM
25mm? That's a significant difference (1"). Are you sure you read the numbers correctly?
My work pc really does not like Neu's website. It takes at least 15 minutes to load the battery page. Worked instantly at home.
10.27.2008, 05:19 PM
100% certain. The site says all the 4100 30c packs are 142 mm long, but my pack was about 167 mm long and I had to trim the polycarbonate sheilding to make it fit in my 162 mm battery holder.
10.27.2008, 05:38 PM
I just popped for a pair of 5500 5S XP's to run my 2.5D. Hope I picked the right ones......
Which balance taps do these come with?
10.27.2008, 06:46 PM
I just picked up the 5500 5s myself, its a damn good deal $100 off what it was selling for previously. It just barely fits in my RC-Monster battery tray, but it does fit. Neu packs have Kokam/Graupner type balance plugs on them.
10.28.2008, 09:18 AM
When you ordered, did you get a purchase confirmation? Mine went straight to the paypal site, I gave them my money, then it just stayed on the same page. I'm going to call them later to see if the order actually went through.
