danhfvcsd
11.23.2005, 08:44 PM
sure will ;) won't be for a week or 2 tho - i actually wasn't expecting it all to arrive so soon, so i'm fairly unprepared -lol-
E-Traxxer
11.27.2005, 07:10 AM
Does anyone know what the mounting holes are on the 1950? Seeing the diameter is the same as the XL's, they should have the same mounting holes..?
Serum
Serum's Avatar
11.27.2005, 07:13 AM
Yeah, 540 sized. the shaft on that motor is 4mm though.
E-Traxxer
11.27.2005, 07:32 AM
Ok, thanks. Looks like i might get one after christmas, and transplant the 10XL into something else.. like *cough* a buggy *cough* :L:
Dafni
Dafni's Avatar
11.27.2005, 08:56 AM
4mm is correct for 1930 and 1940 motors. The 1950 has a 5mm shaft.
coolhandcountry
coolhandcountry's Avatar
11.27.2005, 09:41 AM
I thought the whole line up of the 19 series was a 4mm. You could get 1/8inch shaft for 1930 40. Hey how does that 10 xl do? Get some decent run time.
Peace!
Country
Help support the
Rc-Monster
Buy here
mack
mack's Avatar
11.27.2005, 01:21 PM
What will be the run time whit 2240/8hi-amp on 20 cells
And what is better on the hi-AMP version.
The lehner motors are beter than the XL right.
So if i wand max 20 cells which lehner would be the best choice?
Serum
Serum's Avatar
11.27.2005, 01:33 PM
it is not that the high amp is better, it has got a lower internal resistance, higher KV.. i don't recommend the highamp, i thought we allready talked about this?
wat lehner motors are better than what XL?
my choice would be the wanderer 9XL
mack
mack's Avatar
11.27.2005, 01:45 PM
Yeah that's right we already talkt about it.
But mike said that the lehner whit the same spec's as a (XL9)
will be the beter motor.
So you already tolt me that the 9XL is the best option on 20 cells
But if i want to go whit a lehner on 20 cells,
wich motor is than the beter option,
Serum
Serum's Avatar
11.27.2005, 01:49 PM
The 9XL i am talking about is a lehner/wanderer as well. It is the wanderer. Mike hasn't got a feigao 9XL, so it would be a wanderer any way.
The 9XL is the better option. on 16,18 and 20 cells.
a 1940/10 would be about the same in kv.
mack
mack's Avatar
11.27.2005, 02:07 PM
So what you are saying is that the wanderer is the same quality,
as the lehner.
And so the beter option for my savage.
I'am ask this because i wand to go on and order my sertup.
And you now once orderd i can't go back.
Serum
Serum's Avatar
11.27.2005, 02:13 PM
No, i am not saying that the wanderer is the same quality? what made you think that?
The wanderer has got better bearings, and plugs soldered on allready..
mack
mack's Avatar
11.27.2005, 03:01 PM
The reason I thougt that you ment that, was your following comment in a previous post:
"The 9XL I am talking about is a lehner/wanderer as well. It is the wanderer. Mike hasn't got a feigao 9XL, so it would be a wanderer any way"
So you're saying that I would be better of , for both speed and runtime, with a Wanderer 9XL.
Serum
Serum's Avatar
11.27.2005, 03:23 PM
yeah.
that's the one you want!
give you a nice runtime too
coolhandcountry
11.27.2005, 07:19 PM
I think rene and mack are talking about two different things. The wander motor is better than the feigao for the better bearing but are pretty much identical. The lehner motors like the 19 series is closer to the feigao line up. a 1940 or 1950 series would be closer to the specs of the xl motors. If i understand the question right.
Peace!
Country
Help support the
Rc-Monster
Buy here
