Serum
Serum's Avatar
12.03.2005, 09:20 AM
i would aim a little less high.. lower KV is cool with those HV setups.
VWT4
12.04.2005, 02:09 PM
Finally we will connect 4 battery packs in serie.
I will wire with 4 Ultra Deans male so:
Is it a good idea?
And another female self-conected for a 3 pack setup:
Serum
Serum's Avatar
12.04.2005, 02:14 PM
They are all in serie my friend! parralel is when you put two batteries on eachother, with the + and the - pole
VWT4
12.04.2005, 02:23 PM
:C:
Thks Serum, you're right.
To achieve the 28.8 volts is in serie.
I will correct it.
VWT4
12.07.2005, 11:43 AM
Originally posted by coolhandcountry
Does the 36 95 your friend have have the rpm limit on it. If it does it is not a good idea to push the motor over 42000 rpm cause bad stuff can happen. 14-16 cells sounds like a good candiate for 8xl or 7xl. Depends on run time and speed looking for.
RPM limit is 80.000
mack
mack's Avatar
12.07.2005, 11:58 AM
Originally posted by VWT4
RPM limit is 80.000
The RPM limit coolhand was talking about is for the controller (3695)
And you are talking about the motor
But it isn't very smart to go to the max rpm of the motor
it won't last very long
Than you can beter go for a lover kv (RPM/V)
this way you get lower RPM more torque so you can gear higher
Get the same speed and keep the motor cooler and longer life
Serum
Serum's Avatar
12.07.2005, 12:22 PM
It took an email or 10-15 before i convinced Mack though..
in the HV setups, you don't want a motor to rev too high.. 30-40K is the maxx. RPM i would use.
mack
mack's Avatar
12.07.2005, 12:28 PM
[QUOTE]Originally posted by Serum
[B]It took an email or 10-15 before i convinced Mack though..
That's true bud since I now got your wisdom I have to share it
;) ;) may the force be whit you;) ;)
VWT4
12.07.2005, 02:30 PM
No mack, I am talking about controller RPM limit.
I asked Alexander, from BK electronics in Germany and he said me this model is 80.000 rpm limit.
mack
mack's Avatar
12.07.2005, 03:48 PM
If i'am not wrong you have only a 3695 wiht 42000rpm limit or no limit at all except for the amps thats 95amp.
And on the site of BK you can see that the wandere XL have a max rpm of 80.000.
So I think that Alexander confused the motor rpm with the controller rpm limiter.
VWT4
12.07.2005, 04:13 PM
Alexander sold us the 3695 and said it has a 80.000rpm limit.
Here Mike explains that all 20120 and 20150 controllers and some 3695 are 100k limit .
I will ask to BK again.
EDIT: very fast answer ...
100.000 rpm is the limit of controller and 80.000 rpm the limit on motor
mack
mack's Avatar
12.07.2005, 04:21 PM
[QUOTE]Originally posted by VWT4
[B]Alexander sold us the 3695 and said it has a 80.000rpm limit.
Okay if mike says so then it is so mike is way more experienced
than me.
But I now for a fect that the motor has got a rpm limit of 80.000rpm.
Bud what are we talking about because you will never want to drive your motor to this high rpm right?
VWT4
12.07.2005, 04:28 PM
I will try a 12XL , 55amp and 1390rpm/V :
- 24 cells = 28,8V= 40.000 rpm
- 28 cells 33,6V= 46.700 rpm
"Than you can beter go for a lover kv (RPM/V)
Get the same speed and keep the motor cooler and longer life"
Gustav
Gustav's Avatar
12.07.2005, 07:10 PM
Still a little high ideally IMO.It'll need all the help it can get to keep cool hauling all that weight around.i'd get the 13XL.
mack
mack's Avatar
12.07.2005, 08:19 PM
[B]I will try a 12XL , 55amp and 1390rpm/V :
Please look at what SERUM told you he knows this
"in the HV setups, you don't want a motor to rev too high.. 30-40K is the maxx. RPM i would use."
So that means you have to go to a lower rpm/v.
So I think that what Gustav says the 13XL would be the (max/beter rpm/v) option at 28 cells
