12.02.2008, 01:50 PM
I still think he needs at least one small face-kicking, just for inconveniencing our friend - but after the product arrives.
Well I was annoyed as I kind of am compulsive on these things once I've set my mind on it...
But I traded an old lipo I don't use that much with a little cash so I'm fine... As long as it comes! (And the wife doesn't find out)
12.02.2008, 01:55 PM
Brian - you are the king on painting chasus what do you think will work best - I'm thinking of a gun metal or silver with blue lexan panels.
johnrobholmes
johnrobholmes's Avatar
12.02.2008, 01:56 PM
Outrunners and hard crawling don't really mix well. They cog a ton when a wheel gets stuck, and with large tires it makes it worse. Sensorless is much better suited for a scaler.
Those links and shock mounts would work if you don't want to fab anything. FYI the 3mm threaded ballends will break pretty easy on a clod.
---JRH---
12.02.2008, 02:02 PM
Thanks for the tips - I'll hold off buying anything until I get it and strip it down - Pics to come...
12.14.2008, 10:20 PM
Making some progress...
TexasSP
Something, anything, nothing
TexasSP's Avatar
12.14.2008, 11:42 PM
Looks a dang sight better already. I like silver/gray and blue together.
www.cubicle101.com
12.14.2008, 11:46 PM
Wow, pretty!
Is that made of aluminum or steel tubing? Just curious because I noticed the welds and if aluminum, was wondering how you welded it. I'm looking for a low-cost welding solution for one-off jobs but don't want to spend a ton of cash on a TIG or MIG (can't remember which does al welds).
TexasSP
TexasSP's Avatar
12.14.2008, 11:48 PM
BrianG, miller makes some nice welders for around 3-400 for home type setups. I have seen them in person and the work really well. The are not for industrial use for hours on end, but for the home user they are great.
www.cubicle101.com
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
12.15.2008, 04:45 AM
TIG.
12.15.2008, 10:35 AM
You can do AL with a wire feed mig, but I am not sure if the smaller 120v models will do it. I have a larger Miller Mig (actually have 2 of them) and they have been very good machines. We mainly weld sheet metal (car body panels) but I recently was welding 3"-4" galvanized pipe for my low front fence and swing gates, and that stuff is thick. A good welder is a great investment, that is for sure!
12.15.2008, 11:12 AM
Yeah, I had started a thread about welding aluminum a while back and know my options are to A) Get a good TIG welder and learn how to use it, B) Use that solder type stuff (links in that thread) and deal with the not-so-strong results, or C) find someone local to do the one-off jobs I need to do. I was just hoping there was some new magical/easy/cheap process.
12.15.2008, 12:07 PM
I heard that if you close your eyes really tight and tap your heels together a few times while wishing really hard... Nothing happens.
The local welder will be the cheapest... But having a tig welder would be nice!
Luckily a buddy of mine has welded al since he was 10 so I am covered!
TDC57
TDC57's Avatar
12.15.2008, 10:16 PM
WOW that looks GREAT!!!
Nice job...
Nothing!.. Hahahahaaa..
