What would you build in 09 if you were me??
Or better yet what do you think
I can’t build in 09?? I love proving people wrong..
Here are
four ideas I’ve got / been thinking about doing in 09:
1. I was going to build a turbine powered 1/5 scale with a few extras but that’s been done!,
I'm now thinking about a 4 motor ducted fan hover car with the motors mounted on these pan and tilt servos
http://servocity.com/html/spt200_pan___tilt_system.html
(Curtsey of Arct1k) Thanks again Sir..
2. I was also thinking about cross breading a plane with a car but I'm afraid the weight to wing ratio will not be feasible, I need to investigate this further to know for sure..
3. Then there is the possibility of using 1/5 scale heli foldable blades (hidden of course) but then there’s that dam weight to power ratio thing that I think will kill me. But still how cool would that be for it to expose heli blades and then lift up off the ground firing a paintball gun at someone’s build chasing it about 3-4’ in the air..
4. I was also thinking about taking two zeppelin symbols ( or something) and installing magnets along both sides of the rim on the upper and lower end facing each other and then installing motors within the metal tops & bottom to make it spin, thus using the magnets to fight off each other at high velocity crating lift from the spinning and fans ducts cut into the outer shell, blaa, blaa, blass,
thus creating the first official UFO!... HaHahahahha.. How cool would that BE??!!!
I’ve even got the steering all worked out already!
, it will be controlled by a weight system between the top and bottom, it will tilt in the direction it needs to go controlled by a BL motor. Mad scientists laugh here..
That’s that kind of stuff I'm going for in 09 (OUT OF THE BOX IDEAS!) what has never been done before BUT CAN BE with out the box thinking???? Or IE strictly project “X” material..
So for now, PLEASE don’t really worry about logistics at this point, I’ll take care of that, I just need you to pitch me your wild and crazy ideas and who knows your idea might be my 09 build and or the winner of the RCM 09 custom build award goes to
???? HHHAAA,HHahahhahaha….
Thanks again for all of your time and I'm looking forward to hearing all of your out of the box ideas.
Shaun.
