BL_maxx
01.14.2009, 01:58 AM
sorry this might be of topic but are the 2200kv available seperately? like just the motor. i already have the mmm.
Unsullied_Spy
Unsullied_Spy's Avatar
01.14.2009, 03:55 AM
Not for a while. I think they're trying to fill orders for combos, Traxxas, and HPI right now. Once they can keep up with demand they'll be more readily available.
Right now you should be able to find them on eBay if you want one now.
rotary rocket
No Pistons
rotary rocket's Avatar
01.17.2009, 01:53 AM
Thank you, my kyosho has been waiting for it...
Mike, when do you expect to get your stock? I've been checking the store everyday with no luck.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.23.2009, 10:08 PM
The 2650 combos are enroute and should arrive next week. :)
hagenmi1
01.26.2009, 12:28 AM
So is powering an RC8t with the 2200 way overkill? I like the 2650 but I would rather have more motor if I decided to go over 4s.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.26.2009, 04:52 AM
Put it this way. If you gear the 2200 with a 26 tooth and you gear the 2650 with a 22 tooth you will practically get the same results. Not that you would ever gear that high for either motor, but you get the idea. I have a 2650 kv combo on the way that i will be running on up to 5s. It's the same rpm as the 2200 on 6s so I should be fine for my intended use...
...of showing off in the parking lot for 20 minutes straight that is. lol.
Area 52 Ranch Raceway
T.R.C.R.
01.26.2009, 09:08 AM
Disagree - The 2650 is close to a 1512 and is suitable; for a buggy for a truggy / MT get the 2200 - I've been running both of these motors since september...
You will notice the difference.
SpEEdyBL
SpEEdyBL's Avatar
01.26.2009, 08:26 PM
You have tried both the 2200 and the 2650 in the same vehicle, geared to go the same speed? Was there a difference in the powerband?
I am aware that the 2650 is a 1512 and the 2200 is a 1515, but since they are both 1Y they will have roughly the same resistance and the charts of the neu motors confirm this comparing two lengths of the same wind. Actually the 2200 should have a touch more resistance due to the longer coils, but theoretically, if the resistance is the same in both motors, amp draw will be the same and therefore power since power = volts x amps.
T.R.C.R.
hagenmi1
01.26.2009, 08:12 PM
That's what I was thinking for the RC8t. It seems with the lower kv you have more room to play with the battery. THX, I'm getting back into since the electric hay day of the RC10 so I'm learning.
bensf
01.26.2009, 12:31 AM
Is there any way we can get just the 2650kv motor? Other than eBay that is.
01.26.2009, 09:10 PM
I ran both on a GTP with similar gearing - obviously the 2200 is slower - will try to get some measurements on eagletree but that will be a while....
rotary rocket
No Pistons
01.26.2009, 09:22 PM
Sorry for being off topic...
Bensf, I live in Moraga. I guess we are neighbors. Where do you bash? We should get together one of these days and run our trucks.
Now back on topic. I read a posting by CC that mentions they prefer the 2200 even in a buggy! Now I'm confused, I thought they made the 2650 for 1/8th buggies!!!
Unsullied_Spy
01.27.2009, 10:35 PM
If you want a 70+ MPH Buggy go for the 2200. If you want it to be controllable I'd stick to the 2650.
SpEEdyBL
SpEEdyBL's Avatar
01.27.2009, 10:33 PM
That would be cool if you could get some measurements. What i meant was the 2200 geared with a pinion gear 26.5/22 = 1.2 times as big to get the same top speed for both motors, thats all.
T.R.C.R.
KINGSKID
KINGSKID's Avatar
01.29.2009, 10:59 PM
Originally Posted by Thomas Porfert View Post
Nope, you're not dreaming, you heard right, a massive pallet of the Castle Neu 2650Kv (based on the Neu 1512 series) has finally arrived!
This first batch will only be packaged with combos, as we don't have quite enough to fulfill all of our current backorders.
But for those of you who have been patiently waiting for the 2650Kv combo, the wait will soon be over! We will be doing some spot testing to verify they're up to spec, and then they'll start rolling out. So get your buggies ready, your LiPo's charged and have some spare parts handy because they'll be up and running shortly.
Remember these are shorter than the 2200Kv (based on the Neu 1515), so they're intended for the 1/8th buggies and not the monster trucks.
Thomas Porfert
Castle Tech Support
Thomas,when do you think we'll be able to buy the motors only?
embassyraceway 1922 E main st Niles Mi 49120
final race of 08 sept 13th @ noon
