bdebde
That's All Folks!
bdebde's Avatar
01.25.2009, 07:29 PM
Those are them, diameter is the same, but they are shorter than the LST2 shocks
02.10.2009, 11:20 PM
FYI: I picked up a pair of stock Muggy shocks and they are the same as the LST2 shocks, except they have plastic bodies and black springs.
I also picked up a set of MGT MMT shocks. The website said they use 3.5mm shafts, so I did some calculations from some pictures based on that figure. Well, they came in and they actually have 3mm shafts, so my calculations were wrong and they won't work either. They have about the same bore as your typical buggy.
I now have quite a stockpile of shocks and springs. I'm sure I'll use them eventually. In the meantime, I decided to modify the shocktower so I can use the LST2 shocks. Oh well.
drkdgglr
02.11.2009, 03:22 AM
Thats not the only difference. Muggy shock shafts are shorter than LST2 shafts, and therefore overall length and shock travel are also shorter.
bdebde
That's All Folks!
bdebde's Avatar
02.11.2009, 03:24 AM
If they are the same as the LST2 shocks, then they are not Muggy shocks. They are probably aftershock shocks. Do they match the dimensions I gave? My dimensions were dead on hole center to hole center. If you got them from a chop house on ebay, I would say they made an error. I had that happen to me when buying Muggy diffs one time, got aftershock diff (wrong ratio, but looks the same).
02.11.2009, 03:30 AM
That's what I was hoping for. The LST2 shocks are about 10-15mm too long. But everything else is perfect.
Yeah, they must have made a mistake then because they were the exact same length as the LST2 ones I have. The description specifically said Muggy, not LST or Aftershock. Crap. Anyone want to trade a couple brand new LST2 stock shocks for true Muggy shocks? And if the Muggy shock bore is aluminum, I have a couple of aluminum LST2 shocks I could trade instead.
drkdgglr
02.11.2009, 03:33 AM
The Muggy shock bore is plastic, but is the same size as the LST2's shock bore. You could also just replace the shock shafts of the LST2 shocks with Muggy shock shafts. Then you'll have aluminium Muggy shocks.
edit: http://www.losipartshouse.com/servle...ln--MUG/Detail
02.11.2009, 04:06 AM
I thought of that (replacing just the shaft), but I kinda want a shorter bore and shaft. That will get me the exact length AND range I need. Retaining a longer body would be like pre-compression...
