E-fanatic
Brushless only!
E-fanatic's Avatar
01.31.2009, 02:21 PM
Well the losi's offer better overall grip and are ribbed inside so they don't balloon up at high speed very much. That was there down side b/c even with the slipper set so loose that the truck wouldnt wheely it would still eat a shimmed diff. The badland are more sensitive to steering inputs and offer less grip (so it will help the diffs last longer). They also need to be taped (I used gorilla duck tape ) so the tires wouldnt balloon at higher speed(they are not ribbed inside to prevent it) . Both tires handle completely different! I do like the badlands and would recommend them(the only downside to big lugs on a tire is lak of grip on hard packed surfaces)
Since you have the e-revo I would say go with the badlands b/c the e-revo's diffs cant handle the extream grip and weight of the losi's tires.
How do you tape the tire
alangsam
How do you tape the tire - 01.31.2009, 04:05 PM
Sounds like a silly question but are you putting the tape sticky side towards the inside of the tire? is it single or double sided?
E-fanatic
Brushless only!
E-fanatic's Avatar
01.31.2009, 04:49 PM
Single sided tape(like standard duck tape). Turn the tire inside out and stick the tape all the way around the center (leave about 1 in or so of tape overlap , Oh sticky side towards tire) It really helps performance of the tire at high speeds
azjc
01.31.2009, 05:48 PM
remove the tire from the wheel, turn the tire inside out and run a length of duct tape on the inside of the tire on the area where the main tread is
jhautz
jhautz's Avatar
01.31.2009, 06:04 PM
Get the badlands and zero offset LPR wheels. Cut the bead off of the badlands and mount them on the LPR wheels with the stock foam that comes with the Badland tires. The lower profile on the sidewall and higher foam density from having a slightly overstuffed foam really makes a big difference to reduce the amount of ballooning and you shouldnt need tape on the tires unless you are shoot for some really high speeds.
I prefer zero offset wheels on my revo for track purposes. The zero offset wheels give you close to the stock track width and the revo will turn better. With offset wheels the wider track width makes it turn slower and it fels less responsive from my experience. The 1/2 offset wheels are great for stability if you are running in open areas or speed runs, but it handles better with standard (zero) offet wheels IMO.
to make it...
or break it...
Silent...But Deadly
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.31.2009, 07:24 PM
You tape the inside of the tire below the tread. I use Scotch Strapping Tape, it's a reinforced packing tape.
alangsam
01.31.2009, 07:42 PM
cool. thanks. next question, have pivot balls popping out on the front end from time to time. Whats a good way to harden these?
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.31.2009, 07:55 PM
RPM makes axle carriers that use bigger bearings and have more material around the pillowball.
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
02.07.2009, 11:05 PM
Does your ERevo have the new Traxxas carriers introduced on the Platinum Revo? Part # TRA5334R. They're the ones with the metal ring around the pillow ball hole. They also use a bigger outer bearing. If not then get them, they are cheap and work great. If the 5334R are the ones you're running and managed to pop pillow balls through them then you might need to go heavy duty with RD Racing carriers. The suggested RPM carriers are fine if you don't have the Slayden steering mod done. With the Slayden mod, the RPMs pop pillow balls too. I use the Traxxas 5334R and I have the Slayden mod done and I still have to pop a pillow ball after a full season of racing and bashing. Tekno also came out with their own carriers that have aluminum reinforcements around the pillow ball hole. I never tried those.
No brain, no headaches.
E-fanatic
Brushless only!
E-fanatic's Avatar
02.07.2009, 11:11 PM
Yes they use the ones with the metsl ring and larger bearings. I just broke one and got the part # out of the owners manual and the manual says that the rear uses a 5334(not the r) but then show the larger bearing being used???? I ordered the 5334 and it didnt fit! So I just got the 5334r and I am now back up and running!
Edit: I only broke one b/c it was 19*F outside and hit the ramp doing 40mph and landed sideways(58ft away) on the rear tire!
what is the slayden steering mod?
alangsam
what is the slayden steering mod? - 02.08.2009, 06:52 AM
What is the slayden steering mod? I have the e-revo and installed the part that gives you extra steering but i still dont have as much steering turning to the left as i would like.?
mistercrash
Guelph, Canada, eh!
02.08.2009, 10:52 AM
The Steve Slayden's steering mod
It's simply a few little modifications you can do to get the maximum steering throw from your Revo. But it does come at the expense of pillow balls popping out if you don't have some kind of reinforced carriers like the 5334R from Traxxas or the expensive RD Racing ones.
madmaxx
REVO madman!
madmaxx's Avatar
link to slayden mod's http://www.traxxas.com/support/kb_se...472&artlang=en
look's like mistercrash beat me to it!
you can also mod the stock carrier's with a piece of copper tubing IIRC
are your toe link's set-up equally?
REVO picco .26 << too many mod's to list
TT st-1 OS .30 << stock
CEN matrix FRE OS .21rg
http://ca.geocities.com/jleblao/
what wheels work with the super bolt on tires?
alangsam
what wheels work with the super bolt on tires? - 02.09.2009, 04:52 PM
I ordered the maximizer badlands combo. I also want to know what wheels do the lost super bolts ons fit? will they fit on the 17mm maximizer or do i need a 40 series rim? if so does anyone make a beadlock in a 40 size?
E-fanatic
Brushless only!
E-fanatic's Avatar
02.09.2009, 07:29 PM
The losi tires are 40 series and proline make a set of beadlocks and so does axial(sp ? and they are call oversized beadlocks). I just put a set of the losi superbolt-ons on a set of proline 40 series beadlocks(for my friends lst2). I had to dremmel a little of the rubber off the inside mounting band of the tire to make it fit well in the beadlocks though. Overall it wasnt hard and they bit well in the rim. The losi tires are very grippy
