cdis
02.03.2009, 01:36 AM
Yea, I thought hobbycity did too, but I can only find the adapters to turn 2x 3s packs into a 6s, or split a 6s pack into 2 x 3s :(
My BC8 can do 7 cells, but its only 150W charge, so it'd be slow anyway.
That new 7s hyperion charger looks the goods, but same problem, how to connect up the balance taps on the 4s and 3s? :(
Unsullied_Spy
Unsullied_Spy's Avatar
02.03.2009, 01:38 AM
I think Brian had a post about how to do it, perhaps he'll have some insight on this.
EDIT: I think it involves removing the red wire from one side and running the black wires from both and the red wire of one into a single connector but it's been a while since I saw the thread.
Duster_360
02.03.2009, 11:10 PM
Originally Posted by Unsullied_Spy View Post
There are people that have charged them at 25 amps, but it reduces their run times. A123 actually posted a small chart on another forum showing the expected number of cycles at different charge rates. If I'm not mistaken, 10a should get you at least 500 cycles.
Any chance you remember cycles for 5 amps??? We were told 1000+ cycles was typical but never given a charge rate.
I use a Hyp 0610iNet charger and 25a, 13.8v power supply fwiw.
Unsullied_Spy
02.04.2009, 01:42 AM
I don't remember for sure, but 1,000 cycles sounds feasible. They are very robust cells, if they ever make a cell that's more convenient for RC use I'll definitely be using them.
