Duster_360
02.05.2009, 10:30 PM
[QUOTE=George16;258238]You're not making sense at all. Are you saying that the 16.8V diffs from a 3906 are stronger? The 3906 uses the weak 2-screw diffs while the 16.8V(3905 emaxx) uses the stronger diffs. [QUOTE=George16]
My bad, I read that as the older 3906 diffs he had destroyed. I know all that stuff, I just read it wrong.
Unsullied_Spy
Unsullied_Spy's Avatar
02.05.2009, 11:33 PM
Originally Posted by emaxxter View Post
do you by chance have links to the adapter or can tell me where to get it? is the adapter for the pinion or the output shaft to the wheels?
http://www.rc-monster.com/proddetail...mrevov2coupler
That's the part you'll need to connect the diffs to the center shafts. The hybrid diff should fit just fine. I wouldn't bother with the UE diffs, AFAIK they're Ofna diffs which can be bought much cheaper.
Maxx42
Maxx42's Avatar
02.07.2009, 12:46 PM
Originally Posted by ssspconcepts View Post
If you already have purchased the truggy diffs...I think you could keep them and just use a pinion gear that has a +2 or +3 tooth count and you'd be fine.
It's actually a little more than you'd think, given the spur gear that he may be using. If he's using the 65 tooth spur gear, he would have to add about 6 teeth to his pinion to get the same rpm's at the tires, or he would have to lose about 15 teeth off of his spur gear if he kept the same pinion.
G-Maxx MMM/1515 2D
T4 Factory Team MM/Lehner 3600XL
RC18t 5400 Mamba
MGT 8.0 conversion MMM/1521 1.5D
