E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
02.24.2009, 09:29 PM
Crt.5
36-50-4800-5mm V2
MM esc 2s 5000mah neuenergy hardcase lipo
47t spur 11,12,13,15,17,19t pinions, generally geared for mid 30's depending on tires and terrain
Motor has never been over 130* even on a 90* summer day
Easily get 20min bash sessions
azjc
02.24.2009, 10:44 PM
Hyper 8 buggy
36 60mm 1600kv v2
14/46 gearing
crimefighters
quark 125b (may swap to MMM)
6s 2170 fp 25c lipos
Runs a bit warm, close to 160f on the motor. I may go up to a 15t and see if that helps. The quark stays cool, but one of them poofed so I may swap to the MMM. And it will look cleaner without the ccbec and related wiring.
Linc
what kind of run time were you getting with the 6s 2170 packs and did you have any problems with lack of amperage with the setup? I am planning on setting up a truggy with a leftover Neu 1515/2.5d with a 6s 3700 25c pack and have also thought of the 6s 2500 packs Mike sells.....trying to get an idea on things
02.24.2009, 11:30 PM
Moi:
11lb RTR hyper ST
Medusa 36-70-1600
MMM
neuenergy 6s 4900 25c lipos
13/51 gearing
stock tyres
Finnster
KillaHurtz
Finnster's Avatar
02.27.2009, 12:06 PM
Crt.5
50mm/2200 on 4S 2100 packs
14/46 on M2Ks, upto 18/46 w/ 1/10 buggy tires.
Faster than jesus, and can't keep wheels down. 48 mph or so just on the mashers.
Temps? Always under 120. Stopped checking a while ago.
DARKWAV
02.27.2009, 05:49 PM
HPI E-Savage (Trophy Truck Conversion)
Medusa MR-036-060-3100V2-5
1/8 Buggy Wheels/Tires
65t spur / 20t pinion (Mod .8)
2 in series 2S LiPo 5000 mAh 25C (14.8 V)
Mamba Max, 12V Fan, CC BEC
RC-Monster Heatsink/Clamp
With above setup Estimated 38 MPH. ESC runs 120F and Motor runs about 130F in sunny 60F degree ambient temps. Solid 30 minutes of bashing with little to no stopping.
With 5.5 inch Monster Truck tires (estimate 45 MPH) motor continues to run at about 130F but MM ESC temps escalated to 170 by end of the run. Run time in the 20-25 min range for bashing.
asheck
02.27.2009, 06:29 PM
E-revo
36-60-2000 Medusa heat sink.
MMM
Gearing varies as to what voltage and tires.Currently 20/65 with original Savage tires,on 4s 5200.Great for the rough stuff,but tires limit it to around 38.24/54 with Dirt bonz on 4000 6s,gets 60 mph.
Hottest it's ever been is 165.But I was being stupid running 4s to 50 mph,in the middle of summer,with no heat sink.
After running this motor for about 8 mos,I have to say it's great.I wish I could find an excuse to get the 70-2300,but so far I just can't justify it.
FG101C
02.27.2009, 08:27 PM
Losi 8ight-B
36-70mm 1600kv v2 w/heatsink
16/45, 40/13 internals
4s 5000 30c Flightmax (wish I bought two)
150-155 degrees on the motor, battery and ESC luke warm, perfect mix of speed and control on the track.
37.41 mph.
Not a top speed run buggy, but I don't do speed runs, track use only.
spaz163
Functionality with a dash of Form
spaz163's Avatar
02.27.2009, 08:36 PM
Ofna Ultra MBX 1/8 Buggy:
Airtronics M11 with Spektrum Module
Spektrum Reciever
Airtronics 94358 servo
Mtroniks Genesis Truck ESC
Medusa Afterburner V2 36-60-2000 Motor w/preinstalled heatsink
Geared 15/51
Zippy-R 4s 4800mah, Zippy-H 4s 5000mah
Check it out HERE.
sikeston34m
sikeston34m's Avatar
03.12.2009, 08:50 PM
Wow Guys! What a way to put those Medusa Motors to work. LOL
If you haven't added your Medusa setup to this thread, would you please post it here for all of us to see?
Thanks
03.12.2009, 09:41 PM
My daughter's crt.5
1. mm esc
2. Medusa 50 series 3300kv 5mm shaft
3. TrueRc hard case 2s li-po 5000mah
4. Futaba 125 oz servo
5. Pro line 2.2 Gladiator tires
6. Slingshot white rums/dyed black
ESC settings:
1. timing 2 deg.
2. med start power
3. 30% punch control
4. 60% brakes
5. 3.2 v/c li-po cut off
stock spur..44 I think ....16 pinion
Temps have greatly depended on her driving and where we drive. Sunday she kept thermaling the esc...we were in beach sand which I am sure was 80% of the issue. I have since tweaked the esc a bit...so we shall see.
All in all the esc /motor combo is smooth and plenty for her
q8-maxx
E-Maxx Lover
q8-maxx's Avatar
03.12.2009, 09:43 PM
Originally Posted by q8-maxx View Post
e-maxx
mmm
medusa 36-70-2300 and hv novak heatsink
2x2s 5200mah rcm lipo hardcase
gearing 24/58 (48-52mph)
more than 20 minutes runtime never goes above 150-160
and here is the video http://www.youtube.com/watch?v=s7gGZSHoS2k :)
MMM v1 zippy 2x3s 5000mah neu 1y 1/8 diff's
MMM v3 Rc-monster 2x2s 5200mah-HC medusa 36-70-2300kv
Pic's - video - youtube video's
bruce750i
bruce750i's Avatar
03.13.2009, 12:16 PM
Rustler
MM
Medusa 60mm-2000 / 120-140*F
18/36
2s, 3s & 4s
Hyper-7
MMM v1 no mods
Medusa 70mm-2300 / 140*F
17/46
4s & 6s
Rc8te
MMM V2
Medusa 80mm-2200 / 130-150*F
18/54
4s & 6s
Here is a video of the 80mm in the Hyper-7 running 19/46 on 6s 160*F and rising.
http://s300.photobucket.com/albums/n...t=MOV05612.flv
ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
03.13.2009, 01:27 PM
3905 Maxx
3905 FLM Chassis
Medusa 36-70-1600kv
6s - Zippy Rhino 4900mah
MMM - Normal Timing, Linear Throttle/Brake 30% Punch
22/62 32p
Bow-Tie LPR
Motor Highest Temp 145*
BASHER
GREAT RUNTIME
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
pinkpanda3310
pinkpanda3310's Avatar
03.15.2009, 08:05 AM
e-maxx 3905
36-80-1600
mmm v3
3x (5ah 20c 7.4v)
gearing 23/66
temps on esc and motor around 60C.
Yet to test with timing and add motor heatsink.
Unsullied_Spy
Unsullied_Spy's Avatar
04.22.2009, 05:20 PM
CRT .5
RC-M chassis
2.2 Truck tires
MM
50mm 3300KV
17T Pinion
Hyper 7 TQ
MGM 16018
Street tires
70mm 2000KV
20T Pinion
Muggy
Stock 40 series-sized tires
14-16 pounds depending on setup
MMM
80mm 2000KV
16T Pinion
