macfjej
macfjej's Avatar
01.08.2006, 05:41 PM
so let me get this straight to run the 9920/9l combo, i'm going to need the:
Lage heatsink/clamp
Ubec
programming cable (even though i don't need it for some reason :| )
2 steel idler gears
center mip shafts (already have front & rear)
Strobe kit
Strobe pads (which arn't in stock)
ofna 51 tooth spur
and 2-3 5mm mod1 pionions
that's an awful lot to put down at once, and since the high temp pads are sold out, i think i'll stick with my 12 pegged slipper for right now, could somone recomend what sizes of pinion i should get, since it seems i'll be getting the 5mm version of 32 pitch and still don't know what people use for their 9L setup
Sylvester
Sylvester's Avatar
01.08.2006, 05:45 PM
ok, you have everything right on there, the strobe pads arent a must, you can live without them, and you dont need the programming cable, so you can save a little money on unneeded things.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
macfjej
macfjej's Avatar
01.08.2006, 05:55 PM
but if you didn't use the pads wouldn't it just be runnig metal on metal?
i checked tower hobbies and couldn't find those pads, are they costom made or somthing? who makees them?
squeeforever
squeeforever's Avatar
01.09.2006, 12:15 AM
strobe makes them and the slipper comes with a set. the high temps are just a different pad for a higher horse power app. although i think they come with it.
macfjej
macfjej's Avatar
01.09.2006, 09:50 PM
oops, i thought strobe slipper was the name of the part :o
thx
