Thread Tools Rating: Thread Rating: 18 votes, 5.00 average. Display Modes
Jabe
04.02.2009, 04:20 AM
Originally Posted by Joe Ford View Post
There are several types of caps out there. What was the make/model you purchased/used? What was the application as well? And if you swapped out the receiver for a different one, did it still do it?
What is right cap to use with CCBEC, what specs should cap have, any special?
When application is 2,4Ghz Sanwa + CCBEC + MMM.
pthunell
05.08.2009, 09:59 AM
I could use an answer to this question too.. Please help.
adrictan
06.04.2010, 08:32 AM
When choosing a capacitor for a 14.8v setup, do I choose one that has a higher Voltage or one that has a higher uF?
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
06.04.2010, 10:10 AM
The one used by Spektrum is a 10v 4700µF low ESR aluminum electrolytic capacitor. Part # SPM1600 if you want to buy it direct...$6 with the rx lead already on it.
Joe Ford
Product Specialist
adrictan
06.04.2010, 10:32 AM
So I do not need a cap with a higher voltage when I'm on 14.8v? 10v is enough?
Thomas Porfert
Thomas Porfert's Avatar
06.04.2010, 10:48 AM
10v is fine because the cap is only dealing with the voltage on the receiver; which is anywhere between 4.8-6.0 volts on most setups. So the input voltage won't have any effect on the receiver or capacitor voltage.
Thomas Porfert
Castle Tech Support
Cain
08.27.2010, 02:23 PM
sorry to bring back an old topic, but I figure better than starting a new one?
Anyway, here is what I am experiencing:
At the race recently I decided to put more power into my vehicles while still running my trusty Novak Havoc ESCs. I went from a Novak Ballistic 13.5 to a 8.5 for both 2wd 1/10 buggy and 2wd SCT.
The power was right on just like how I like, but I had some instances of what I would describe as a brown out. during the runs, it seemed as if all of a sudden I lost power to the motor, then it would come on again and be fine. Servo steering was fine.
This would happen about midway in the race. I was advised by others they have experienced this too. Adding to this, at some point someone yelled to the marshalls to turn the car off then on to "reset" the esc as they had experienced this before with there havoc usage.
Temps on the motor and ESC were 150s & 130s respectively.
I am using high power servos, which makes me wonder if I need a glitch buster cap?
Any ideas?
