whitrzac
Can't catch this...
whitrzac's Avatar
04.15.2009, 05:30 PM
I just put my slash body on the stretched chassis jato i have. Wheelbase is off a bit, but the width is very close. You may get it just right if you can mount the slash rear rims all the way round. You would need to mod the front hubs, as the jato uses bearings in the wheels, and the slash wheels have 12mm hexes. You may be able to just use rustler vxl c hubs and knuckles with the jato arms. People put jato arms on rustler and pedes, so I am sure that they will fit. Sounds like a fun project. If my chassis was 1/2 shorter the wb would be perfect. I bet the axial br50 body would fit... That truck uses a truggy chassis so the body must be longer.
While I am at it... does anyone want to buy a stretched chassis jato roller?
I'm making my own chassis thats 2in longer than stock
I plan on running the SC10 wheels...
whitrzac
Can't catch this...
whitrzac's Avatar
04.15.2009, 08:22 PM
now that I have more time,
you shoulda seen the look on the tech ed teacher when I said I needed some 7075 alloythen falowed up with the "why not make it outa steel?"
but the chassis I'm makeing is 2in longer, won't have the cutouts/holes for the nitro stuff, and will be semetrical.
I think I may rip the novak trays off my 1/8 buggy, thats on hold because of $$, and run 2 2s batteries in parallel to get uber long runtimes or 4s when I want to fly
any idea if a castle 4600 motor will work without too much heat issues untill I can get a novak HV, or a speed passion motor, or a tekin motor
does anyone have the 2 speed internals/brake kit for it?? it allready has the singal speed conversion, and no matter how useless it is, its still cool
any ideas on things I should add onto the chassis, or other custom parts I should make??
I see alot of people using an E-maxx motor plate, does it bolt right up or does it need alot of work??
whitrzac
Can't catch this...
whitrzac's Avatar
04.17.2009, 09:09 AM
just out of curiosity, how do you think it will fair against an sc10??
whitrzac
Can't catch this...
whitrzac's Avatar
04.19.2009, 10:20 PM
update: its a 2-speed!! thanks to brian
a 4x12ft sheet of 7075 t6 mill finish is on its way to the school ($150) the welding lab said they would buy whatever I don't use, soo it looks like I'll need a few more ideas
the plan is to buy a new top plate and keep the RX box, and servo mounts, but cut out the batt mount and mount a 5000mah 2s between them. the esc will go next to the RX box on the chassis.
any ideas on extending the body mounts?? or how to mount at least the front bumper?
williamg
04.20.2009, 11:48 AM
ofna parts
http://www3.towerhobbies.com/cgi-bin...?&I=LXBZN1&P=7
and or
http://www3.towerhobbies.com/cgi-bin...?&I=LXBZN0&P=7
I've used them, very universl and easy to setup
04.20.2009, 01:17 PM
Originally Posted by whitrzac View Post
...a 4x12ft sheet of 7075 t6 ...
Is that a misprint? 4 feet by 12 feet?
Anyway, your parts will be shipped in about an hour during my lunch break.
whitrzac
Can't catch this...
whitrzac's Avatar
04.20.2009, 03:31 PM
yes, 4ftx12ft... costs $150... but I only have to buy what I use
I'm going to make a chassis for my 1/8 buggy and my slash while I'm at it
whitrzac
Can't catch this...
whitrzac's Avatar
04.20.2009, 07:57 PM
now, the question is, do I go with 1/8 buggy tires, or stay with 2.2 truck tires??
I have some of both...
any cheaper versions of these??
http://cgi.ebay.com/Traxxas-Jato-17M...QQcmdZViewItem
whitrzac
Can't catch this...
whitrzac's Avatar
04.20.2009, 10:32 PM
shoulda done some more reasarce before I bid, could had a BIN for $25...
ether way, still an awsome deal for good shocks
http://cgi.ebay.com/ws/eBayISAPI.dll...EOIBSA:US:1123
I'v got the front body mount on(slash mount), i think I'll have to order on of the ofna bony mounts for the rear...
I'll have a prototype chassis made out of steel tomarow
whitrzac
Can't catch this...
whitrzac's Avatar
04.22.2009, 11:30 AM
the 7075 plate should be here thurs or fri
I have a cupple unanswered questions...
any recommendations on a CHEAP motor for it?? I'm thinking a feigao just to get me by for awhile...(witch one???)
if not a feigao then will something like a CC 4600, or a novak 10.5(13mm rotor) be up to running this beast what I have...
whats the recommended wheel/tire?? 1/8 or 1/10?
what angle should I bend the sides of the chasis up? I know the more I go the stiffer it will get, but how stiff is too stiff...
since I'm making a custom motor mount, what distance should the motor shaft be from the top shaft on the tranny??
are there any slightly wider corr bodys that have the same wheelbase as the slash??
whitrzac
Can't catch this...
whitrzac's Avatar
04.23.2009, 09:52 AM
what angle should I bend the sides of the chassis up? I know the more I go the stiffer it will get, but how stiff is too stiff...
anyone??
halfcab
halfcab's Avatar
04.23.2009, 07:21 PM
the velineon traxxas motor should run quite a bit cooler and just begs for 3s to be a flyerand a velineon should be a bunch cheaper, around $40 on the bay usually when I have looked, my cc 5700 and my 4600 get pretty hot in my slash, the velineon in a freinds slash runs an easy 20-30 deg cooler, not sure if the gearing is lower in the jato or not but I would try the velineon over the cc motors for it
mmm v1/cc bec
neu 1515 1y f
ofna hyper7
several crawlers scalers and comp rigs
cc 4600 mm sys in a slash and a stock slash
soon to be reserected gorilla maxx v2
whitrzac
Can't catch this...
whitrzac's Avatar
04.23.2009, 08:15 PM
well, I allready have a CC 4600 motor...
I might giv the 10.5/13mm a try though, it has the heatsink sleave on it
whitrzac
Can't catch this...
whitrzac's Avatar
04.25.2009, 05:40 PM
update: I'v got the e-maxx motor plate instaled, the brakes on, and the 2 speed trany in.
still waiting on the alloy to arive....
for a motor, I bought a "hobbycity" brand 36-50 6s 5900kv for $20 shipped from a guy on RCU... I should fly I also have a 'hobbycity' 36-60 9l motor from the same guy on the way....
the front body posts are strait off the slash, and the rear will probably be just a single post from AE...
the brake servo will be right behind the motor, and the reciver will be in the stock location....
brushlessboy16
brushlessboy16's Avatar
04.25.2009, 06:13 PM
6s seems a bit weak for this truck.. Might wanna use the 9l
