Originally Posted by pb4ugo
I have to disagree. The 1100 series should be about perfect for 1/10th. I've been running a Feigao 380 for ever, others were running the Lehner 15 series, even the Novak has a rotor similarly sized to a 1100 series. The 1100 series will put out up to 1000 watts in the longest versions, probably about 600 watts in the 1107 variety, plenty if not overkill for 1/10th 2wd. My plan is to upgrade my Feigao (in a T4) for an 1107.
OP, if you do decide to use the 1107, remember that you will need an adapter plate to match it up to your motor plate holes.
Thanks, I'll keep the 1107 in mind, but the price of the Madusa sure is atractive.
